The 620A series is a single display mount with a flexible arm that increases productivity by freeing up desk space with more efficient display positioning. Installation is quick and easy, and secures a display with a quick release mechanism. Instantly set the height of the display by raising or lowering it 12.6", extending up to 22", and tilting forward and back. Furthermore, the LCW620A can pan and rotate for comfortable portrait or landscape viewing.
- Peerless 620A Series Wall Mount LCW620A mounting kit - for LCD display - black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Articulating arm, wall mount
- Adjustments
- Pan, tilt
- Recommended Use
- LCD display
- Recommended Display Size
- 19"-30"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 9 kg
- Black
- Black
AV Furniture
- Mounting kit
- Recommended Use
- LCD display
- Placing / Mounting
- Wall-mountable
- Cable Management
- Integrated cable management
- 19"-30"
- Adjustments
- Pan, tilt
- Max Load Weight
- 9 kg
- Adjustable height, rotating, portrait to landscape movement, swivel adjustment
