The MOD-ADF Pole Drill Fixture serves as a template for marking and positioning installation holes to be drilled into newly cut 2" (50 mm) poles.
Versatile mounting
Designed for both LCD displays and projectors, the Peerless Modular Series MOD-ADF offers a flexible solution for your AV setup needs. Its mounting component ensures a secure and stable installation, making it an ideal choice for various environments. -
Easy installation
The pole drill fixture included with the Peerless Modular Series MOD-ADF simplifies the installation process. This feature allows for a straightforward setup, ensuring your AV equipment is mounted efficiently and effectively.
- Peerless Modular Series MOD-ADF mounting component - for LCD display/projector - black powder coat
- Product Type
- Mounting component
- Mounting Components
- Pole drill fixture
- 6.6 cm x 8.2 cm x 6.6 cm
- 0.45 kg
- Recommended Use
- LCD display/projector
- Black powder coat
- 6.6 cm
- 8.2 cm
- 6.6 cm
- 0.45 kg
- Black powder coat
AV Furniture
- Recommended Use
