Peerless-AV Accessory Drill Fixture for 50mm Pole
Quicklinx: 9Z17WS00 Mfr#: MOD-ADF
£42.14 ex VAT
£50.56 inc VAT
The MOD-ADF Pole Drill Fixture serves as a template for marking and positioning installation holes to be drilled into newly cut 2" (50 mm) poles.
  • Versatile mounting
    Designed for both LCD displays and projectors, the Peerless Modular Series MOD-ADF offers a flexible solution for your AV setup needs. Its mounting component ensures a secure and stable installation, making it an ideal choice for various environments.
  • Easy installation
    The pole drill fixture included with the Peerless Modular Series MOD-ADF simplifies the installation process. This feature allows for a straightforward setup, ensuring your AV equipment is mounted efficiently and effectively.
Peerless Modular Series MOD-ADF mounting component - for LCD display/projector - black powder coat
Mounting component
Mounting Components
Pole drill fixture
6.6 cm x 8.2 cm x 6.6 cm
0.45 kg
Recommended Use
Black powder coat
6.6 cm
8.2 cm
6.6 cm
0.45 kg
Black powder coat
AV Furniture
Mounting component
Mounting Components
Pole drill fixture
Recommended Use
Brand: Peerless-AV
