Peerless-AV Accessory Cover for MOD-CPF Ceiling Plate
Quicklinx: 9Z16WS00 Mfr#: MOD-ACF
£54.58 ex VAT
£65.49 inc VAT
The Peerless-AV modular mounts line features a full range of products that can fulfill multiple requirements from a limited number of SKUs. With the universality of the components, configure your own perfect custom flat-panel display or projector mounting solution for any application.
The modular mount line was developed with the professional AV installer in mind. Designed around a 2" (50 mm) diameter pole, the line is ideal for new projects as well as for upgrading existing installations.
Peerless MOD-ACF-W mounting component - for flat panel / projector - white powder coat
Mounting component
Mounting Components
Ceiling plate cover
17.6 cm x 20.5 cm x 3.1 cm
Recommended Use
Flat panel / projector
White powder coat
P/N: MOD-CPF
17.6 cm
20.5 cm
3.1 cm
White powder coat
AV Furniture
Mounting component
Mounting Components
Ceiling plate cover
Recommended Use
P/N: MOD-CPF
Brand: Peerless-AV
