Peerless-AV 80" TV Trolley
Quicklinx: 8G4DWS00 Mfr#: SC590
The SC590 Flat Panel Floor Cart offers the most complete mobile solution for any large screen application. This versatile presentation cart allows you to hold meetings with AV support or simply to display information. A full line of accessories enable each cart to be fully tailored to meet your specific requirements.
Peerless Flat Panel Floor Cart SC590 cart - for flat panel - black powder coat
Cart
137.1 cm x 66 cm x 160 cm
Adjustments
Tilt
44.6 kg
Recommended Use
Flat panel
Recommended Display Size
32"-90"
VESA Mounting Interface
800 x 400 mm
Max Load Weight
136 kg
Black powder coat
5-year warranty
137.1 cm
66 cm
160 cm
44.6 kg
Black powder coat
AV Furniture
Cart
Recommended Use
Flat panel
800 x 400 mm
Cable Management
Integrated cable management
32"-90"
Adjustments
Tilt
Max Load Weight
136 kg
Wheel Diameter
10.2 cm
Swivel adjustment
Limited warranty - 5 years
