The Adjustable Extension Column features a tube-in-tube design notched and threaded 1 1/2- 11.5 NPT at the lower end. The upper end has a pin fitting for attachment to a compatible Peerless ceiling fixture.
- Peerless ADD 0608 mounting component - black
- Product Type
- Mounting component
- Mounting Components
- Extension column
- Adjustable Height
- 180-240 cm
- 9 kg
- Black
- Adjustable Height
- 180-240 cm
- 9 kg
- Black
AV Furniture
- Extension column
- Adjustable height, bolt fixing
