Designed particularly for professional AV applications the Modular Series includes excellent features that reduce installation time and maximize versatility.
Versatile mounting
The Peerless Modular Series Extension Pole is designed to offer a flexible solution for your AV mounting needs. This extension pole can be easily integrated with other Peerless Modular Series components, allowing for a customized setup that meets your specific requirements. -
Durable construction
Crafted with high-quality materials, the Extension Pole ensures reliability and durability. Its robust design supports your AV equipment securely, providing peace of mind and a stable foundation for your displays or projectors.
- Peerless Modular Series Extension Pole mounting component - chrome
- Product Type
- Mounting component
- Mounting Components
- Extension pole
- 5.08 cm x 5.08 cm x 2 m
- Chrome
- 5.08 cm
- 5.08 cm
- 2 m
- Chrome
AV Furniture
- Extension pole
