Peerless-AV 1m 50mm Diameter Extension Pole
Quicklinx: CNL2WS00 Mfr#: MOD-P100-B
£34.91 ex VAT
£41.89 inc VAT
The Peerless-AV modular mounts line features a full range of products that can fulfill multiple requirements from a limited number of SKUs. With the universality of the components, configure your own perfect custom flat-panel display or projector mounting solution for any application.
The modular mount line was developed with the professional AV installer in mind. Designed around a 2" diameter pole, the line is ideal for projects as well as for upgrading existing installations.
The MOD-P100-B extension pole is designed for use with the Peerless-AV modular series mounts. They offer perfect solution for tailoring each unique installation with custom cut-to-length poles.
  • Versatile mounting
    The Peerless Extension Poles MOD-P100-B offers a versatile mounting component, designed to enhance your AV furniture setup. Its extension pole feature allows for an adjustable viewing experience, ensuring your AV equipment is positioned at the perfect height and angle for optimal viewing.
  • Seamless integration
    Crafted for seamless integration, this mounting component from Peerless Industries is engineered to fit perfectly with your existing AV furniture. Its sleek design and durability ensure a reliable solution for elevating your audiovisual setup.
Peerless Extension Poles MOD-P100-B mounting component - black
Mounting component
Mounting Components
Extension pole
50 cm 1 m
50 cm
1 m
AV Furniture
Mounting component
Mounting Components
Extension pole
