In a pot or in the ground, the Parrot Flower Power monitors and analyzes the four parameters essential to your plant's health. Whenever your Flower Power detects that your attention is needed, you will receive notification on your smartphone or tablet which uses Bluetooth Smart to connect to Flower Power. You will know when to water them, add fertilizer, or repot your plant to ensure its well-being, and yours!
Your sensor assesses your plants' needs
In a pot or in the ground, the Parrot Flower Power monitors and analyzes the four parameters essential to your plant's health. -
The App sends alerts to your smartphone
Whenever your Flower Power detects that your attention is needed, you will receive notification on your smartphone or tablet which uses Bluetooth Smart to connect to Flower Power. -
You take care of your plants
- Parrot Flower Power - plant sensor
- Product Type
- Plant sensor
- Environment
- Indoor, outdoor
- Sensor Type
- Sunlight, temperature, fertiliser, moisture
- Functions
- Temperature measuring, fertiliser measuring, soil moisture measuring, luminosity measuring
- Connectivity
- Wireless - Bluetooth 4.0
- Supported Host Device OS
- iOS, Android
- Brown
- 64 mm x 32 mm x 190 mm
- Product Type
- Plant sensor
- Sensor Type
- Environment
- Indoor, outdoor
- Functions
- Connectivity Technology
- iOS, Android
- Push notification, 7000 plants PlantDB, indoor/outdoor usage, water-resistant
Internet of Things (IoT)
- Compatible Services
- IFTTT
- CPU
- CC2540 CC2540
- Manufacturer
- Texas Instruments
- Included Accessories
- AAA rechargeable battery
- Brown
- 64 mm
- 32 mm
- 190 mm
- 45 g
- -10 °C
- 55 °C
