Panoview 120" Motorised Screen - 16:9
Quicklinx: 5G9XWS00 Mfr#: DE-9120EGA
This product is one of the only screens on the market that has a built in IR remote control. The screens aluminum casing also has an over-ride switch located at the end of the case. Depending on installation, both the built-in I/R and external infrared remote systems can be used.
Tubular motors are known to be quiet and noiseless, stable, and smooth. Raise and lower your projection screen smoothly and precisely with the touch of a button. The tubular motor is the heart of this motorized projection screen and will give you years of reliable and trouble-free operation.
EGA screens feature one of the best mounting systems on the market. The floating L-bracket design allows for horizontal adjustments and therefore the brackets can be fixed at any preferred point on the screen casing. Tightening screens ensure the screen remains locked and secure.
Optoma Panoview DE-9120EGA - projection screen - 120" (305 cm)
Projection screen - motorised
Package Content
IR remote control
Projection Screen Image Diagonal Size
120" (305 cm)
Projection Image Size
266 cm x 149 cm
Aspect Ratio
16:9
Screen Surface
Matte White
Product Material
Fibreglass
298 cm x 9 cm x 9.5 cm
14.8 kg
Optoma H117ST, H185X, H190X, HD28B, HZ40STx, UHD35, UHD35x, UHD38
Package Content
IR remote control
Image Diagonal Size
120" (305 cm)
Image Width
266 cm
Image Height
149 cm
Screen Surface
Matte White
Aspect Ratio
16:9
Gain
1.0x
Black borders
Product Material
Fibreglass
298 cm - 9 cm - 9.5 cm
14.8 kg
