Panoview 120" Electric Screen
Quicklinx: 5HHZWS00 Mfr#: DE-3120EGA
Accessory Type: Projection screen
Hurry, only 1 left in stock!
£499.84 ex VAT
£599.80 inc VAT
One of the only screens on the market has a built in IR remote control. The screens aluminum casing also has an over-ride switch located at the end of the case. Depending on installation, both the built-in I/R and external infrared remote systems can be used.
Tubular motors are known to be quiet and noiseless, stable, and smooth. Raise and lower your projection screen smoothly and precisely with the touch of a button. The tubular motor is the heart of this motorized projection screen and will give you years of reliable and trouble-free operation.
EGA screens feature one of the best mounting systems on the market. The floating L-bracket design allows for horizontal adjustments and therefore the brackets can be fixed at any preferred point on the screen casing. Tightening screens ensure the screen remains locked and secure.
Optoma Panoview DE-3120EGA - projection screen - 120" (305 cm)
Projection screen - motorised
Projection Screen Image Diagonal Size
120" (305 cm)
Projection Image Size
234 cm x 176 cm
Aspect Ratio
4:3
Screen Surface
Matte White
Product Material
Fibreglass
261 cm x 9.5 cm x 9 cm
15.3 kg
Image Diagonal Size
120" (305 cm)
Image Width
234 cm
Image Height
176 cm
Screen Surface
Matte White
Aspect Ratio
4:3
Gain
1.0x
Black borders
Product Material
Fibreglass
261 cm - 9.5 cm - 9 cm
15.3 kg
Remote control
Brand: Panoview
Price Range Ex VAT: 300 - 500
