Panasonic WJ-SX650/G Video Multiplexer 256 Channels
Quicklinx: BCKLWS00 Mfr#: WJ-SX650/G
The Matrix System 650 from Panasonic is the easier way to configure mid-sized to large surveillance systems. This remarkable system makes it simple to fully integrate up to 256 cameras, 32 monitors, and 60 registered users. The Matrix System 650 is a simple, flexible architecture that makes it ideal for a wide range of applications including shopping malls, multipurpose complexes, office buildings and banks.
Panasonic WJ-SX650/G - video multiplexer - 256 channels
Video multiplexer - rack-mountable
Video Channels
256
Voltage
120 V
42 cm - 37.2 cm - 26.5 cm
19 kg
Video Channels
256
Video Input Ports
BNC x 32
Video Input Signal Level
1.0Vp-p 75 Ohm
Video Output Ports
25 pin D-sub x 4, BNC x 16
Video Output Signal Level
1.0Vp-p 75 Ohm
Alarm Input Ports
37 pin D-sub
Other Ports
Serial RS-232 x 1
Voltage
120 V
Frequency
60 Hz
Power Consumption
60 Watt
42 cm
37.2 cm
26.5 cm
19 kg
-10 °C
50 °C
0 - 90%
