Panasonic VW-VBG130E-K Battery
Quicklinx: 6NZMWS00 Mfr#: VW-VBG130E-K
Panasonic batteries are developed and tested for maximum performance in all your high drain products. Panasonic batteries are the driving force of the portable age. And the innovation, reliability and durability that you've come to expect and rely on from the Panasonic brand name, ensure Panasonic batteries are the product you can trust for the ultimate power and performance in all of today's high-tech and digital electronics.
Panasonic VW-VBG130E-K camcorder battery - Li-Ion
Camcorder battery
Lithium Ion - 1250 mAh
Panasonic AG-HSC1, HSC1U, HSC1UE, HDC-HS100, HS200, HS300, SD10, SD20, SD600, SD7, SD700, SD707, SDT750, TM10, TM200, TM700, NV-GS230, GS320, GS330, GS500, GS60, GS80, GS90, PV-GS320, GS80, GS83, GS85, GS90, SDR-H18, H80; AVCCAM AG-HMC40, HMC45; AVCHD-AG-AC7; AVCHD Pro HDC-MDH1; Palmcorder PV-GS80
Camcorder battery
Camcorder
Lithium Ion
Voltage Provided
7.2 V
1250 mAh
Panasonic AG-HSC1, AG-HSC1U, AG-HSC1UE, HDC-HS100EG, HDC-HS200EG-K, HDC-HS200EP-K, HDC-HS250K, HDC-HS300EC-K, HDC-HS300P-K, HDC-HS300PU-K, HDC-HS9EP-S, HDC-SD10, HDC-SD100EPK, HDC-SD10EB-K, HDC-SD10EB-R, HDC-SD10EC-K, HDC-SD10EC-R, HDC-SD10EF-K, HDC-SD10EG-K, HDC-SD10EG-S, HDC-SD10EP-K, HDC-SD10EP-S, HDC-SD10K, HDC-SD200EC-K, HDC-SD20EC-R, HDC-SD20EC-S, HDC-SD20EP-K, HDC-SD20EP-R, HDC-SD20R, HDC-SD20S, HDC-SD300, HDC-SD300EG-K, HDC-SD600EBK, HDC-SD600EC-K, HDC-SD600EG-K, HDC-SD7, HDC-SD700, HDC-SD700EBK, HDC-SD700ECK, HDC-SD700EF-K, HDC-SD700EGK, HDC-SD700EPK, HDC-SD707, HDC-SD707EGK, HDC-SD707EG-K, HDC-SD707EGS, HDC-SD707EG-S, HDC-SD9EP-S, HDC-SDT750, HDC-SDT750EG-K, HDC-TM10, HDC-TM10EB-S, HDC-TM10EC-K, HDC-TM10EP-K, HDC-TM10K, HDC-TM10S, HDC-TM200, HDC-TM20EP-K, HDC-TM20K8, HDC-TM20R, HDC-TM20S, HDC-TM300EC-K, HDC-TM700, HDC-TM700EBK, HDC-TM700ECK, HDC-TM700EF-K, HDC-TM700EG-K, HDC-TM700K, NV-GS230, NV-GS230EB-S, NV-GS230EF-S, NV-GS230EG-S, NV-GS230EP-S, NV-GS230E-S, NV-GS230GN, NV-GS320, NV-GS320EB-S, NV-GS320EF-S, NV-GS320EG-S, NV-GS320EP-S, NV-GS320E-S, NV-GS330, NV-GS330EB-S, NV-GS330EG-S, NV-GS330EP-S, NV-GS500, NV-GS500EB-S, NV-GS500EG-S, NV-GS500EP-S, NV-GS500GN-S, NV-GS60, NV-GS60E9-S, NV-GS60EB9-S, NV-GS60EB-S, NV-GS60EG9-S, NV-GS60EG-S, NV-GS60EP9-S, NV-GS60EP-S, NV-GS60GN, NV-GS80, NV-GS80EB-S, NV-GS80EF-S, NV-GS80EG9-S, NV-GS80EG-S, NV-GS80EP-S, NV-GS80E-S, NV-GS90, NV-GS90EB-S, NV-GS90EG-S, NV-GS90EP-S, PV-GS320, PV-GS80, PV-GS83, PV-GS85, PV-GS90, PV-GS90PL-S, SDR-H18P, SDR-H41, SDR-H80EC9-A, SDR-H80EC9-K, SDR-H80EC9-R, SDR-H80EG9-K, SDR-H80EG9-R, SDR-H80EG9-S, SDR-H80EP-A, SDR-H80EP-K, SDR-H80EP-R, SDR-H80EP-S, SDR-H80PU-A, SDR-H80PU-K, SDR-H80PU-R, SDR-H80PU-S, SDR-H90EF9-K, SDR-H90EG9-K, SDR-H90EP-K, VDR-D160EP-S, VDR-D220EP-S, VDR-D310EP-S , Panasonic AVCCAM AG-HMC40, AG-HMC45 , Panasonic AVCHD-AG-AC7 , Panasonic AVCHD Pro HDC-MDH1 , Panasonic Palmcorder PV-GS80 , Panasonic VDR-D50EP-S, D51
