Ultra-short throw projectors can project images onto a large 80-inch screen with a short projection distance of 0.32m. These projectors can be installed either horizontally or vertically to meet various installation requirements. The 3D projections make classes, seminars, events and exhibitions more impressive and effective, providing a wider range of uses.
- Panasonic PT-CW230EA - DLP projector - 3D
- DLP projector - 720p
- 3D Capable
- Built-in Devices
- Speaker
- Networking
- Ethernet, Fast Ethernet
- Brightness
- 2500 lumens
- Contrast Ratio
- 2000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 16.7 million colours
- Bulb type
- UHM 275 Watt
- Bulb life cycle
- Up to 2000 hour(s) - normal mode , Up to 3000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 480i, 525i, 525p, 625p, 625i, 576i, 576p, 1080/60i, 720/60p, 1080/50i, 720/50p, 750/50p, 750/60p, 1125/60i, 1125/50i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 350 Watt
- 32.1 cm x 38.6 cm x 17.8 cm
- 6.2 kg
- 3D Capable
- Built-in Devices
- Speaker
- Networking
- Ethernet
- Data Link Protocol
Projector
- Brightness
- 2500 lumens
- Contrast Ratio
- 2000:1
- Throw Ratio
- 0.19:1
- Uniformity
- 80 %
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Video Bandwidth
- 150 MHz
- Display Format
- 1,024,000 pixels
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 93 kHz
- Bulb type
- UHM 275 Watt
- Bulb life cycle
- Closed Caption, High-bandwidth Digital Content Protection System (HDCP), NVIDIA 3D Vision, DLP 3D Ready, PJlink, Image Freeze Function, Ultra Short Throw Technology, Direct Power Off, DLP Link
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.5
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -5/ +5
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel - 3.7 cm
Input Device
- External
- 1 x HDMI input - 19 pin HDMI Type A , 1 x 3D glasses - 3 PIN mini-DIN , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 PIN DIN , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C input - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 (management) , 1 x component video / RGB output - 15 pin HD D-Sub (HD-15)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable - 1.8 m
- Security Features
- ISO 9001
- Voltage Required
- 350 Watt
- Power Consumption Operational (Standby)
- 0.45 Watt
- 32.1 cm
- 38.6 cm
- 17.8 cm
- 6.2 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
- Sound Emission
- 36 dB
- Sound Emission (Economic Mode)
- 28 dB
