It's easy to view images with the SD card slot. Watch and show your photos right after you take them. Simply insert an SD Memory Card into VIERA to display photos on the large screen. VIERA Link allows the interlinked operation of various AV devices using only the VIERA remote control, by simply connecting the devices to each other by an HDMI cable. In Game Mode, quicker image response increases the enjoyment of video games when a game console is connected to the TV. What's more, VIERA produces the dark images in video games more clearly. This mode works with the anti-image retention (wobbling) function, too. V-Audio Surround produces a depth-sound-image effect by early-reflection data based on actual room measurement, that is generated from the digital signal processor. Equipped with a PC input terminal, it is easy to connect VIERA to a personal computer. PC screen images can then be displayed onto VIERA's large screen.
- Diagonal Size (inches)
- 18.5 in
- Technology
- LCD
- HD Standard
- 1080p (FullHD)
- HDMI Inputs
- 1
- Interface
- Component, Composite, HDMI
- Aspect Ratio
- 16:9
- Audio System / Sound Output Mode
- Surround Sound
- Contrast Ratio
- 20,000:1
- Freeview Bult In
- Freeview
- Native Resolution
- 1,366 x 768
- Product Line
- Panasonic TX
- Television / Diagonal Size (cm)
- 47 cm
- Television / Type
- LCD TV
- Viewing Angle
- Horizontal: 170 degree/Vertical: 160 degree
