The generation of high brightness LCD panels are great for boosting colors and vibrancy. But they can only truly improve contrast if you can control their brightness in dark picture areas. Local dimming makes this possible by letting separate clusters of a TV's backlights output different brightness levels, so brightness can be reduced for dark areas without compromising the intensity of bright areas.
Cue the Quad Core Pro engine. This cleverly separates the smart TV processing from the picture processing, so the smart elements run faster and smoother while pictures look cleaner, crisper and more refined - regardless of whether they're web streams, broadcasts, Blu-rays or 4K feeds.
4K UHD TVs can deliver up to four times as much resolution as Full HD TVs. As you would expect, this means you can see far more detail and texture in 4K UHD pictures, but colors also look more natural, objects look more solid and almost three dimensional, and the extra detail creates a greater sense of depth. Many describe the 4K effect as feeling more like looking through a window than watching a screen. Especially when all that extra resolution is backed up by the wealth of high-end picture quality features Panasonic brings to its 2015 4K UHD TVs.
Local dimming - enhanced blacks for a more natural picture
The generation of high brightness LCD panels are great for boosting colors and vibrancy. But they can only truly improve contrast if you can control their brightness in dark picture areas. Local dimming makes this possible by letting separate clusters of a TV's backlights output different brightness levels, so brightness can be reduced for dark areas without compromising the intensity of bright areas. -
Quad Core Pro - detailed, crisp images from any source
Cue the Quad Core Pro engine. This cleverly separates the smart TV processing from the picture processing, so the smart elements run faster and smoother while pictures look cleaner, crisper and more refined - regardless of whether they're web streams, broadcasts, Blu-rays or 4K feeds. -
Mastering the magic of light
4K UHD TVs can deliver up to four times as much resolution as Full HD TVs. As you would expect, this means you can see far more detail and texture in 4K UHD pictures, but colors also look more natural, objects look more solid and almost three dimensional, and the extra detail creates a greater sense of depth. Many describe the 4K effect as feeling more like looking through a window than watching a screen. Especially when all that extra resolution is backed up by the wealth of high-end picture quality features Panasonic brings to its 2015 4K UHD TVs. -
4K Ultra HD - delivers four times the picture resolution of a normal HD TV
With their 3840 x 2160 resolutions, 4K Ultra HD TVs make pictures look so detailed and pristine that you feel like you're looking at the real world through a window rather than watching TV. Especially when features like high brightness/high color space panels and the powerful Quad Core Pro engine are on hand to tease out every last tiny detail 4K has to offer. -
Studio Master Color - an advanced LED backlight design which produces a wider color range
By using special wide color phosphor technology capable of producing a wider color range, It covers more than 90% of DCI standards. Studio Master Color TVs give you a more subtle, naturally toned color palette which, unlike most LCD TVs, still looks authentic in any scene.
- Panasonic TX-55CX680B VIERA - 55" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 55"
- Glossy black with top and bottom dark silver ornament
- Platform
- Firefox OS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Frame Rate & Enhancement Technology
- 200 Hz BMR
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 3 ports
- Connectivity
- Wi-Fi, LAN
- HDCP Compatible
- LCD Backlight Technology
- LED backlight local dimming
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-T, DVB-T2
- Internet Streaming Services
- Netflix, Amazon Video, Internet Apps (Simple), FREETIME, Panasonic Media Center App, Freeview Play
- Multi-channel Preview
- Picture-and-text (PAT)
- Picture Enhancements
- Wide Colour Phosphor Panel
- Speaker System
- 2 speakers
- Sound Effects
- VR-Audio True Surround
- USB
- 3 ports
- Included Accessories
- Remote control
- Voltage
- AC 230V (50/60 Hz)
- Energy Class
- Class B
- Power Consumption (On mode)
- 130 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 181 kWh
- Dimensions (WxDxH) - without stand
- 124.2 cm x 5.6 cm x 71.9 cm
- 19.5 kg
- Product Type
- Energy Class
- Class B
- 130 W
- 181 kWh
- Diagonal Class
- 55"
- Series
- VIERA
- Platform
- Firefox OS
- Video Processor
- Quad-Core Pro
- TV Tuner
- TV Tuner Presence
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI Ports Qty
- 3 ports
- HDCP Compatible
- Modes
- Game mode, Dynamic Picture Mode, hotel mode
- Dimensions
- Without stand
- 124.2 cm
- 5.6 cm
- 71.9 cm
- 19.5 kg
- Enclosure Colour
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- 200 Hz BMR
- Viewing Angle
- 176 degrees
- Viewing Angle (Vertical)
- 176 degrees
- Brilliant Contrast, My Stream, Voice Assistant, 4K Pure Direct, TV Anywhere, Studio Master Color, Studio Master Drive, My Home Screen 2.0, Easy Mirroring, Super Bright Panel, Info Frame
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Dark metal
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- DVB-T, DVB-T2
Video Features
- Teletext
- Teletext Memory
- 1000 pages
- Electronic Programme Guide
- Digital EPG
Media Player
- Supported Video Formats
- MPEG-4, WMV, MKV, VOB, FLV, TS, AVC, 3GPP, PS, M4V, VRO, HEVC, VP9
- Supported Audio Formats
- MP3, WMA, WAV, AAC, FLAC (Free Lossless Audio Codec), Apple Lossless
- Supported Pictures Formats
- JPEG
- USB Port
- USB Ports Qty
- 3
Remote Control
- Remote control
- Remote Control App Support
Audio System
- Digital Audio Format
- Dolby Digital Plus output
- Surround Mode
- Sound Effects
- Audio Controls
- Sound mode
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Audio Return Channel (ARC), Voice Guidance
- Speakers
- 2 x main channel speaker - 10 Watt
- Driver Details
- Main channel speaker: 2 x full-range driver
Network & Internet Multimedia
- Connectivity
- Wi-Fi, LAN
- Encryption
- DTCP-IP
- Connect & Share
- Swipe & Share
- Supported Consumer Electronics Control (CEC)
- VIERA Link
- DLNA
- Connector Type
- HDMI input - side , 2 x USB 2.0 - side , SCART - rear , Digital audio output (optical) - bottom , Headphones - side , Composite video / component video / audio input - rear , LAN - rear , 2 x HDMI - bottom , USB 3.0 - side
- IEC 62087 Edition 2
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 124.2 cm x 5.6 cm x 71.9 cm x 19.5 kg , Panel with stand - 124.2 cm x 29.2 cm x 76.1 cm x 21 kg
- Width (Shipping)
- 167.5 cm
- Depth (Shipping)
- 15.1 cm
- Height (Shipping)
- 81.2 cm
- Weight (Shipping)
- 27 kg
