Panasonic TX-55CX680B 55" 3840x2160 HDMI USB 4K Ultra HD LED TV
Quicklinx: C84SWS00 Mfr#: TX-55CX680B
  • DVB-T
The generation of high brightness LCD panels are great for boosting colors and vibrancy. But they can only truly improve contrast if you can control their brightness in dark picture areas. Local dimming makes this possible by letting separate clusters of a TV's backlights output different brightness levels, so brightness can be reduced for dark areas without compromising the intensity of bright areas.
Cue the Quad Core Pro engine. This cleverly separates the smart TV processing from the picture processing, so the smart elements run faster and smoother while pictures look cleaner, crisper and more refined - regardless of whether they're web streams, broadcasts, Blu-rays or 4K feeds.
4K UHD TVs can deliver up to four times as much resolution as Full HD TVs. As you would expect, this means you can see far more detail and texture in 4K UHD pictures, but colors also look more natural, objects look more solid and almost three dimensional, and the extra detail creates a greater sense of depth. Many describe the 4K effect as feeling more like looking through a window than watching a screen. Especially when all that extra resolution is backed up by the wealth of high-end picture quality features Panasonic brings to its 2015 4K UHD TVs.
  • Local dimming - enhanced blacks for a more natural picture
  • Quad Core Pro - detailed, crisp images from any source
  • Mastering the magic of light
  • 4K Ultra HD - delivers four times the picture resolution of a normal HD TV
    With their 3840 x 2160 resolutions, 4K Ultra HD TVs make pictures look so detailed and pristine that you feel like you're looking at the real world through a window rather than watching TV. Especially when features like high brightness/high color space panels and the powerful Quad Core Pro engine are on hand to tease out every last tiny detail 4K has to offer.
  • Studio Master Color - an advanced LED backlight design which produces a wider color range
    By using special wide color phosphor technology capable of producing a wider color range, It covers more than 90% of DCI standards. Studio Master Color TVs give you a more subtle, naturally toned color palette which, unlike most LCD TVs, still looks authentic in any scene.
Panasonic TX-55CX680B VIERA - 55" LED-backlit LCD TV - 4K
LED-backlit LCD TV - Smart TV
Diagonal Class
55"
Glossy black with top and bottom dark silver ornament
Platform
Firefox OS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Frame Rate & Enhancement Technology
200 Hz BMR
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
3 ports
Wi-Fi, LAN
HDCP Compatible
LCD Backlight Technology
LED backlight local dimming
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-T, DVB-T2
Internet Streaming Services
Netflix, Amazon Video, Internet Apps (Simple), FREETIME, Panasonic Media Center App, Freeview Play
Multi-channel Preview
Picture-and-text (PAT)
Picture Enhancements
Wide Colour Phosphor Panel
Speaker System
2 speakers
Sound Effects
VR-Audio True Surround
USB
3 ports
Remote control
Voltage
AC 230V (50/60 Hz)
Energy Class
Class B
Power Consumption (On mode)
130 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
181 kWh
124.2 cm x 5.6 cm x 71.9 cm
19.5 kg
Energy Class
Class B
130 W
181 kWh
Diagonal Class
55"
Series
VIERA
Platform
Firefox OS
Video Processor
Quad-Core Pro
TV Tuner
TV Tuner Presence
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
3 ports
HDCP Compatible
Modes
Game mode, Dynamic Picture Mode, hotel mode
Dimensions
Without stand
124.2 cm
5.6 cm
71.9 cm
19.5 kg
Enclosure Colour
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
200 Hz BMR
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Brilliant Contrast, My Stream, Voice Assistant, 4K Pure Direct, TV Anywhere, Studio Master Color, Studio Master Drive, My Home Screen 2.0, Easy Mirroring, Super Bright Panel, Info Frame
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Dark metal
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
DVB-T, DVB-T2
Video Features
Teletext
Teletext Memory
1000 pages
Electronic Programme Guide
Digital EPG
Media Player
Supported Video Formats
MPEG-4, WMV, MKV, VOB, FLV, TS, AVC, 3GPP, PS, M4V, VRO, HEVC, VP9
Supported Audio Formats
MP3, WMA, WAV, AAC, FLAC (Free Lossless Audio Codec), Apple Lossless
Supported Pictures Formats
JPEG
USB Port
USB Ports Qty
3
Remote Control
Remote control
Remote Control App Support
Audio System
Digital Audio Format
Dolby Digital Plus output
Surround Mode
Sound Effects
Audio Controls
Sound mode
Speaker System
2 speakers
Output Power / Total
20 Watt
Audio Return Channel (ARC), Voice Guidance
Speakers
2 x main channel speaker - 10 Watt
Driver Details
Main channel speaker: 2 x full-range driver
Network & Internet Multimedia
Wi-Fi, LAN
Encryption
DTCP-IP
Connect & Share
Swipe & Share
Supported Consumer Electronics Control (CEC)
VIERA Link
DLNA
Connector Type
HDMI input - side , 2 x USB 2.0 - side , SCART - rear , Digital audio output (optical) - bottom , Headphones - side , Composite video / component video / audio input - rear , LAN - rear , 2 x HDMI - bottom , USB 3.0 - side
IEC 62087 Edition 2
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.5 Watt
Dimensions & Weight Details
Panel without stand - 124.2 cm x 5.6 cm x 71.9 cm x 19.5 kg , Panel with stand - 124.2 cm x 29.2 cm x 76.1 cm x 21 kg
Width (Shipping)
167.5 cm
Depth (Shipping)
15.1 cm
Height (Shipping)
81.2 cm
Weight (Shipping)
27 kg
