Uncompromising 4K picture quality is yours with this 4K Ultra HD LED TV featuring an HDMI 2.0 terminal. With every film or program, you'll marvel at the deep blacks, bright whites and vivid colors in all their full glory.
Easy viewing of photos you took in a large screen
Content stored in a USB memory stick can easily be played back on VIERA's large screen. A wealth of customization functions let you add background music and effects. -
HDMI 2.0
So you can enjoy the full effect and impact of 4K Ultra HD. VIERA offers HDMI 2.0 connectivity. Simply hook up your various devices - such as a Blu-ray recorder or gaming consoles - via HDMI 2.0 to the TVs dedicated terminal. You'll get uncompressed picture quality that remains brilliant with vivid colors, strong contrasts and sharp contours. With HDMI 2.0. 4K UHD has never looked better.
- Panasonic TX-40CX400B VIERA - 40" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 40"
- Black
- 3D
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Frame Rate & Enhancement Technology
- 200 Hz RMR
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 4 ports
- Connectivity
- LAN
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- Internet Streaming Services
- Internet Apps (Simple)
- USB
- 3 ports
- Included Accessories
- Panasonic RC48125(RC5) remote control
- Voltage
- AC 230V (50/60 Hz)
- Energy Class
- Class A
- Power Consumption (On mode)
- 63 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 91 kWh
- Dimensions (WxDxH) - without stand
- 91.2 cm x 6.5 cm x 53.2 cm
- Product Type
- Energy Class
- Class A
- 63 W
- 91 kWh
- Diagonal Class
- 40"
- Series
- VIERA
- 3D
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 4 ports
- Modes
- Dynamic Picture Mode
- Design
- Ultra Narrow Bezel Concept
- Dimensions
- Without stand
- 91.2 cm
- 6.5 cm
- 53.2 cm
- Enclosure Colour
- Black
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- 200 Hz RMR
- Direct-lit LED
- Viewing Angle
- 176 degrees
- Viewing Angle (Vertical)
- 176 degrees
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Chrome
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- HDTV Tuner
Video Features
- Teletext
- Teletext Memory
- 1000 pages
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- USB Ports Qty
- 3
Remote Control
- Remote control
- Remote Control Model
Audio System
- Surround Mode
Network & Internet Multimedia
- Connectivity
- LAN
- DLNA
- Connector Type
- 4 x HDMI input - side , 3 x USB 2.0 , SCART , Digital audio output (optical) , Headphones , Composite video / component video / audio input , LAN
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 91.2 cm x 6.5 cm x 53.2 cm , Panel with stand - 91.2 cm x 27.1 cm x 59.3 cm
