Panasonic toughbook CF19 SU9300 ATEX
Quicklinx: 723SWS00 Mfr#: CF-19K3RAXAE
  • Core 2 Duo
The Toughbook 19 features a 10.1" LCD capable of up to 6000 nit in direct sunlight, and is powered by Windows 7. Integrated options include a 3-megapixel camera, backlit keyboard (emissive or rubber), GPS receiver, 4G LTE multi carrier mobile broadband and a multi touch and digitizer LCD that can work with any type of glove. In addition, a 6-feet drop and IP65 certified design with a full magnesium alloy case, helps to ensure that the Toughbook 19 will stand up to the most rigorous environments.
Panasonic Toughbook 19 - 10.4" - Core 2 Duo SU9300
Tablet PC
Intel Core 2 Duo SU9300 / 1.2 GHz
DDR2
Display
10.4" 1024 x 768
Input Device
Keyboard, touchpad
Security
Trusted Platform Module (TPM 1.2) Security Chip
21.6 cm
Tablet PC
Processor / Chipset
CPU
Number of Cores
Dual-Core
DDR2 SDRAM
Display
10.4"
Resolution
1024 x 768
Widescreen
No
Audio & Video
High Definition Audio
Input
Keyboard, touchpad
Lithium Ion
Installed Qty
1
AC Adapter
Input
Connections & Expansion
Memory Card Reader
Yes (SD Card)
Security
21.6 cm
