The Toughbook 19 features a 10.1" sunlight-viewable touchscreen with Panasonic CircuLumin technology, and Intel processor with vPro technology. In addition, a 6-foot drop & IP65 certified design with a full magnesium alloy case, helps to ensure that the Toughbook 19 will stand up to the most rigorous environments.
- Panasonic Toughbook 19 - 10.1" - Intel Core i5 - 3610ME - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook - convertible - rugged
- Operating System
- Win 7 Pro + Windows 8.1 Pro Licence
- Processor
- Intel Core i5 (3rd Gen) - 3610ME / 2.7 GHz, up to 3.3 GHz / 3 MB Cache
- Memory
- 4 GB DDR3
- Storage
- 500 GB HDD
- Display
- 10.1" LED backlight touchscreen 1024 x 768 / XGA
- Graphics
- Intel HD Graphics 4000
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Ambient light sensor
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 27.1 cm x 21.6 cm x 4.9 cm
- 2.3 kg
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Microsoft Windows 7 Professional + Windows 8.1 Pro Licence
Processor / Chipset
- CPU
- Intel Core i5 (3rd Gen) 3610ME / 2.7 GHz
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Chipset
- Mobile Intel QM77 Express
- Intel Turbo Boost Technology 2.0, Intel vPro Technology, Intel Smart Cache
- RAM
- 4 GB
- Max RAM Supported
- 8 GB
- Technology
- DDR3 SDRAM
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s
Display
- 10.1"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 1024 x 768 (XGA)
- Widescreen
- No
- Transmissive, sunlight readable, TransflectivePlus
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Dynamic Video Memory Technology 5.0
- Max Allocated RAM Size
- 1696 MB
- Sound
- Speaker
- High Definition Audio
Input
- Keyboard, touchpad
Communications
- Wireless
- Bluetooth Class
- Class 1
- Wireless Controller
- Intel Centrino Advanced-N 6235
- Network Interface
- Gigabit Ethernet
- Technology
- Lithium Ion
- Capacity
- 5700 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 16 V, 5 A
Connections & Expansion
- Slots
- 1 x PC Card (1 free) , 1 x ExpressCard/54 (1 free)
- Dock , VGA , Headphone output , Microphone input , Serial , 2 x aerial , USB 2.0 , USB 3.0 , 4-pin FireWire , LAN
- Memory Card Reader
- Yes (SD Card, SDXC Card)
Software
- Software Included
- Concealed Mode Utility, Panasonic Dashboard
- Case Material
- Magnesium alloy
- Integrated Options
- Dockable
- Security
- Security lock slot (cable lock sold separately), water-resistant, dust-resistant, anti-vibration, drop-resistant, resistive touch screen, password security, hand strap
- Included Accessories
- Power adapter
- ACPI, IEC 60529 IPX5, MIL-STD 810G 514.6, MIL-STD 810G 516.6, MIL-STD 810G 510.5, JIS C 0920, IEC 60529 IP6X, MIL-STD 810G 506.5
- 2.3 kg
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.89 |
