Panasonic TH-65LFB70E 65" 1920 x 1080 DVI HDMI LCD Display
Quicklinx: CBYQWS00 Mfr#: TH-65LFB70E
  • 1080p
The TH-65LFB70 is a multi-touch brilliant Full HD touchscreen which absolutely anyone can use! The LFB70 professional Full HD display incorporates intuitive touch screen technology, fully interactive whiteboard functionality, and the very latest in wireless connectivity to allow you and your colleagues to work more closely as a team. This display is loaded with the next-generation technology you need to be more productive, more efficient, and to achieve better quality results.
  • Simple touch control
    Progress smoothly through your presentation using familiar touch screen gestures to turn pages, zoom in and out content, and navigate through multimedia functions without need of a remote control. Whether using a fingertip to cue content for a presentation, or the stylus pen to jot down notes for the group, you'll be delighted at how this user-friendly touch interface makes complex tasks simple.
  • Work together on the screen
    Built-in whiteboard software lets you turn on the display and start work right away - no need to connect a PC. Up to four people can write at a time, and you can save your pages and email them directly to anyone who missed the meeting, Notes can be made on almost anything, from video and photos to PowerPoint and PDF documents, and then saved as an image file - simply brilliant for the office or classroom.
  • More productive remote meetings
    With vibrant Full HD resolution and a wide display area, remote videoconference participants seem like they're in the room with you. Team members in remote locations can write detailed notes onto shared documents and solve problems in real time, just as they would when working together in the office. There powerful web and video conferencing capabilities reduce the need for travel, saving your organization time and money.
Panasonic TH-65LFB70E LFB70 - 65" LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Input Video Formats
575/50i, 575/50p, 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i, 1080/24sF
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
Wi-Fi, LAN
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
VA
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Input lock, button lock, remote control user level
Speaker System
2 speakers
USB
Remote control, software kit, 2 AA batteries, eraser, 2 pen styluses, stylus stand
Voltage
AC 230V (50/60 Hz)
215 Watt
Power Consumption Stand by
0.5 Watt
151.7 cm x 10.6 cm x 89.2 cm
58 kg
215 Watt
Diagonal Class
65"
Commercial Use
Combined With
Touchscreen
Series
LFB70
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Landscape mode, 1:1 Pixel Mode
Dimensions
Without stand
151.7 cm
10.6 cm
89.2 cm
58 kg
Enclosure Colour
Display
LCD Display Technology
VA
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Coating
Anti-glare
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Widescreen Modes
Zoom
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
6.5 ms
Backlight Life
50,000 hour(s)
Commercial Features
Infrared multitouch technology, Input Search Function
Stands & Mounts
Flat Panel Mount Interface
684 x 300 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 852 x 480, 1152 x 870, 640 x 400, 1920 x 1080, 1440 x 900, 1280 x 800, 1066 x 600, 1400 x 1050
Media Player
Supported Video Formats
MPEG-4, WMV, AVI, MOV
Supported Pictures Formats
BMP, JPG
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Wi-Fi, LAN
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11b, 802.11g, 802.11n, 802.11a
Encryption
128-bit WEP, 64-bit WEP, WPA-PSK (TKIP), WPA2, WPA2-PSK (AES)
Supported Consumer Electronics Control (CEC)
PJ Link
Connector Type
USB - side , USB - side , Composite video input - rear , Component video input - rear , VGA output - rear , VGA input - rear , Serial - rear , DVI-D input - rear , 2 x audio line-in - rear , Speakers output - rear , 2 x HDMI - rear , LAN - rear
Software kit, 2 AA batteries, eraser, 2 pen styluses, stylus stand
USB cable - 2 m
GOST, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, EN 60065, IEC 60065
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.5 Watt
Power Consumption Sleep
0.3 Watt
No signal power off
Width (Shipping)
171.4 cm
Depth (Shipping)
28.2 cm
Height (Shipping)
102.3 cm
Weight (Shipping)
68 kg
20 - 80% (non-condensing)
