In addition to the high resolution of Full-HD and the wide viewing angle of the IPS panel, the LF25 series features 500-cd/m2 brightness and 9-ms response. This makes it possible to display crisp, clear images even in bright places, for signage with excellent information transmission performance.
The LF25 series has various input terminals including component or RGB input, composite video input, S-Video input, PC input and RS-232C control port input. It's also equipped with HDMI 1/2 inputs with deep color, and DVI-D input with HDCP for high definition signals.
Versatile functions for public information displays
In addition to the high resolution of Full-HD and the wide viewing angle of the IPS panel, the LF25 series features 500-cd/m2 brightness and 9-ms response. This makes it possible to display crisp, clear images even in bright places, for signage with excellent information transmission performance. -
Standard features include highly versatile terminals
The LF25 series has various input terminals including component or RGB input, composite video input, S-Video input, PC input and RS-232C control port input. It's also equipped with HDMI 1/2 inputs with deep color, and DVI-D input with HDCP for high definition signals. -
Narrow bezel and multi display
The bezel on the TH-42LF25ER is only 18.3 mm wide. It is a most suitable model for multi screen display. The video image and graphics can be displayed in greatly by using two or more displays. The effect of the digital signage a high noteworthy level is achieved by decorating the wall with the video image. -
Eco mode
The light sensor detects the ambient light level and control the brightness of the backlight accordingly. This maintains optimum display brightness. It also helps to save energy by reducing the backlight power consumption.
- Panasonic TH-42LF25ER LF25 - 42" LCD flat panel display - Full HD
- Product Type
- LCD flat panel display
- Diagonal Class
- 42"
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 575/50i, 575/50p, 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i
- Video Interface
- Component, composite, HDMI, S-Video
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Technology
- IPS
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Sound Output Mode
- Stereo
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Voltage
- AC 230V (50/60 Hz)
- 240 Watt
- 96.8 cm x 10.1 cm x 56.1 cm
- 18 kg
- Product Type
- 240 Watt
- Diagonal Class
- 42"
- Series
- LF25
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Modes
- Portrait mode, landscape mode, 1:1 Pixel Mode, Seam Hides Video Mode
- Design
- Fanless Design
- Protection
- Dustproof
- 96.8 cm
- 10.1 cm
- 56.1 cm
- 18 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Image Contrast Ratio
- 1200:1
- Brightness
- 500 cd/m²
- Widescreen Modes
- Zoom
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 9 ms
- Backlight Life
- 50,000 hour(s)
- Multi-display setup, Automatic Picture Positioning
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
- Analogue Video Input Signals
- NTSC, PAL, SECAM, NTSC4.43, PAL-M, PAL-N, PAL60
- Supported Computer Resolutions
- 1366 x 768, 1920 x 1200 (WUXGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 720 x 400, 852 x 480, 1152 x 900, 1360 x 768, 640 x 400, 1920 x 1080, 1280 x 800, 1066 x 600, 1400 x 1050
Remote Control
- Remote control
Audio System
- Sound Output Mode
- Stereo
- Speaker System
- 2 speakers
- Output Power / Total
- 10 Watt
- Speakers
- 2 x main channel speaker - 5 Watt
- Connector Type
- Composite video input , S-Video input , 2 x audio line-in , 2 x HDMI input , Component video input , DVI-D input , VGA input , Audio line-in , Serial
- Plug and Play, GOST, DDC-2B, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, EN 60065, IEC 60065
- Power Device
- Power supply - internal
- Input Voltage
- Power Consumption Stand by / Sleep
- 0.2 Watt
- Auto On/Off
- Width (Shipping)
- 110 cm
- Depth (Shipping)
- 21 cm
- Height (Shipping)
- 70.7 cm
- Weight (Shipping)
- 23 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
