The front speakers feature Panasonic's unique Twin Centre design. Thanks to this technology, the sound seems to come right from within the screen, even with a big-screen TV, so dialogue is crisp, clear and easy to understand. For a good home cinema system you need speakers with a performance that matches the clear, vivid, high-resolution images and a design that matches the flat-panel display. Panasonic created the SB-TP1000 speaker system with these exact points in mind. The front speakers feature Panasonic's new Twin Centre design. Thanks to this technology, the sound seems to come right from within the screen, even with a big-screen TV, so dialogue is crisp, clear and easy to understand. Equipped with a Super Sonic Tweeter that delivers pure, clean sounds up to the ultra-high 100 kHz range, the SB-TP1000 speaker system also beautifully reproduces high-quality sources such as full-specification DVD-Audio. Front, centre, and surround speakers all feature a PP Mica Graphite Woofer that delivers crisp, natural mid-level and bass sounds and a Titanium Dome Tweeter that faithfully reproduces treble sounds all the way to 50 kHz. These speakers create a remarkably true-to-life ambience and deliver a seamless surround sound effect when reproducing the super-high-quality sound offered on Blu-ray discs. Added to this is a Dual Drive System and two potent 100-W amps that allow the subwoofer to generate deep, throbbing bass sounds while suppressing unwanted vibration. It reproduces sounds all the way down to 28 Hz. All speakers (other than the subwoofer) can be mounted on the wall to create a theatre-like look that coordinates well with the flat-panel TV. These features make Panasonic's SB-TP1000 the perfect speaker system for your HD home cinema setup.
All speakers (except the subwoofer) can be mounted on the wall to create a theatre-like look that coordinates well with the flat-panel TV. These features make Panasonic's SB-TP1000 the perfect speaker system for your HD home cinema setup
