Panasonic SDR-S50 White inc Battery & Case
Quicklinx: 70TLWS00 Mfr#: SDRS50EBWBUNDLE
  • SDHC Memory Card
Using an SDXC/SDHC/SD memory card for recording media, the compact SDR-S50 is ideal for daily use. Its superb resistance to external impact combines to give this versatile camcorder easy portability for anytime, anywhere video fun. Video clips recorded on an SDXC/SDHC/SD memory card can be played by simply inserting the card into the card slot of a Panasonic VIERA TV.
This compact camcorder features a powerful 70x optical zoom lens with an enhanced optical 78x zoom function that uses the effective area of the CCD to further extend their zooming power at the wide-angle setting. This makes it possible to capture beautiful images of sweeping landscapes and pull in distant subjects for truly dynamic close-ups.
Panasonic SDR-S50EB-W - camcorder - storage: flash card
Camcorder - widescreen
Media Type
Flash card
Memory Card Slot
SD card
Sensor Resolution
800 KP
Effective Sensor Resolution
Video: 520 KP - Photo: 0.52 MP
Lens System
Zoom lens - 70x zoom - 1.48 - 104 mm - f/1.9-5.7
Focus Adjustment
Automatic, manual
Digital Zoom
3500x
Image Stabiliser
Optical (Advanced O.I.S.)
Display
LCD display - 2.7"
Supported Battery
1 x Li-ion rechargeable battery - 895 mAh (included)
Composite video/audio, USB 2.0
White
5.5 cm x 10.7 cm x 6.4 cm
212 g
Camcorder
Enclosure Colour
White
Camcorder Type
Consumer
Camcorder Sensor Resolution
800 KP
Sensor Qty
1 CCD
Effective Video Resolution
520 KP
Effective Photo Resolution
0.52 MP
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
CCD
Optical Sensor Size
1/8"
Optical Zoom
70x
Digital Zoom
3500x
Video Recording Modes
SP, LP, XP, LSP, LXP
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Services and Applications
YouTube capture mode
Print Standard
DPOF support, PictBridge support
Auto Focus
TTL contrast detection
Digital Video Format
MPEG-2, H.264
Image Recording Format
JPEG
Exposure & White Balance
Min Illumination
2 lux
Exposure Modes
Programme, automatic, manual
Shooting Programs
Spotlight, portrait mode, scenery, fireworks, low light, night scene, sports mode, sunset, beach, snow
White Balance
Custom, automatic, presets
White Balance Presets
Cloudy, sunlight, indoor, outdoor
Max Shutter Speed
1/8000 sec
Min Shutter Speed
1/25 sec
Lens System
Focal Length Equivalent to 35mm Camera
32.8 - 2571mm
Focus Adjustment
Automatic, manual
Zoom Adjustment
Motorised drive
Built-in lens shield
Additional Features
Low Lux / Night Mode
Additional Features
Built-in speaker, backlight compensation, Intelligent Scene Selector, AF/AE tracking, Intelligent Contrast Control, Pre-Rec function, face detection, built-in help guide, automatic display brightness adjustment
Display
2.7" LCD display
Display Format
123,200 pixels
Display Form Factor
Rotating
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Zoom, wind noise reduction
Connector Type
USB , Composite video/audio output , DC power input
Software
Software
Drivers & Utilities, Panasonic VideoCam Suite
Power adapter, USB cable, audio / video cable
Battery Type
Lithium Ion - manufacturer-specific
Details
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 640 x 480 , JPEG 640 x 360
5.5 cm
10.7 cm
6.4 cm
212 g
