Enhanced brightness
The 230 W UHM lamp ensures your presentations are vivid and brightly illuminated, enhancing visibility and clarity for all viewers. -
Seamless compatibility
Designed specifically for PC use, this projector lamp integrates smoothly with your existing setup, offering a hassle-free upgrade or replacement solution.
- Panasonic ET-LAT100 - projector lamp
- Product Type
- Projector lamp - UHM - 230 Watt
- Designed For
- PT-TW230, TW230EA, TW230U, TW231R, TW231RE, TW231RU
- Product Type
- Projector lamp
Lamp
- UHM
- Capacity
- 230 Watt
- Designed For
- Panasonic PT-TW230, TW230EA, TW230U, TW231R, TW231RE, TW231RU
