Enhanced Brightness
The Panasonic ET LAD120W projector lamp is equipped with a 420 W UHM lamp, offering enhanced brightness for your presentations and media. This high-capacity lamp ensures your images are vivid and clear, enhancing the viewing experience in various lighting conditions. -
Seamless Compatibility
Designed specifically for compatibility with PC systems, this projector lamp integrates seamlessly into your existing setup. Its precise engineering ensures reliable performance and compatibility, making it an ideal choice for both professional and personal use.
- Panasonic ET-LAD120W - projector lamp
- Product Type
- Projector lamp - UHM - 420 Watt
- Packaged Quantity
- 2 (specifications are for single item)
- Designed For
- PT-DW830, DW830ULW, DX100, DX100EK, DX100ELK, DZ870, DZ870E, DZ870EK, DZ870ULW, DZ870UW
- Packaged Quantity
- Product Type
- Projector lamp
Lamp
- UHM
- Capacity
- 420 Watt
- Designed For
- Panasonic PT-DW830, DW830ULW, DX100, DX100EK, DX100ELK, DZ870, DZ870E, DZ870EK, DZ870ULW, DZ870UW
