Panasonic PT DX500E - DLP Projector - 4500 ANSI lumens - XGA (1024 x 768) - 4:3
Quicklinx: 7VNZWS00 Mfr#: PT-DX500E
  • High-Definition Multimedia Interface (HDMI)
With the advanced lamp modulation technology, the projector is now able to control the lamp intensity for each of the red, green, blue and white segments of the color wheel separately. Because the actual light output is controlled in relation to each color segment, light usage is optimized and color balance is obtained without lowering the brightness. This results in bright, vivid images with increased color fidelity.
This unique control technology optimizes the use of the color segment areas of the color wheel. It increases the brightness of each RGB color by minimizing the unallocated portions between the colors, to achieve truly vivid coloring.
  • RGB booster significantly improves color reproduction
    The RGB booster achieves high image quality with levels of color reproduction and brightness that make each color stand out. It combines Panasonic's proprietary vivid color control technology with a lamp modulation drive system for a 1-chip DLP projector that produces bright and vivid colors.
  • Vivid color control
  • Lamp modulation drive system
Panasonic PT-DX500E - DLP projector
DLP projector
Ethernet, Fast Ethernet
Brightness
4500 lumens
Contrast Ratio
2000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Lens Shift Direction
Horizontal, vertical
Bulb type
UHM 300 Watt
Bulb life cycle
Up to 2000 hour(s) - normal mode , Up to 3000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Digital Video Standard
Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 480i, 576p, 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i, 1035/60i
415 Watt
33.2 cm x 48.5 cm x 16.8 cm
8.5 kg
DLP projector
Ethernet
Projector
Brightness
4500 lumens
Contrast Ratio
2000:1
Image Size
102 cm - 762 cm
Throw Ratio
1.51 - 3.05:1
Uniformity
90 %
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Video Bandwidth
162 MHz
Display Format
786,432 pixels
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
UHM 300 Watt
Bulb life cycle
Integrated de-interlacer (progressive scan), Closed Caption, High-bandwidth Digital Content Protection System (HDCP), Daylight View Technology, Side-by-Side, Detail Clarity Processor 3, 3:2 pull down compensation, Deep Color, PJlink, 3D Color Management, digital noise reduction, RGB Booster, Vivid Color Control, DICOM Simulation Mode
Lens
Focus Type
Manual
Lens Aperture
F/2.0-3.4
Zoom Type
Manual
Zoom Factor
2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Lens Shift Type
Manual
Vertical Lens Shift
60%
Horizontal Lens Shift
10% / 10%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, DVI
Video Modes
Input Device
External
1 x HDMI input - 19 pin HDMI Type A , 1 x DVI-D input - 24+1 pin digital DVI , 1 x component video / RGB input - BNC x 5 , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - BNC , 1 x S-video input - 4 PIN DIN , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C input - 9 pin D-Sub (DB-9) , 1 x remote control input - 9 pin D-Sub (DB-9) , 1 x network - RJ-45
Wireless remote control
Security Features
Password protection, text superimposing
ISO 9001, ISO 14001
415 Watt
Power Consumption Operational (Standby)
15 Watt
Software Included
Drivers & Utilities, Wireless Manager Mobile Edition 5.5
33.2 cm
48.5 cm
16.8 cm
8.5 kg
45 °C
20 - 80%
