Power Supply Input
DC 15.6 V [Do not use other than the specified AC adaptor (Model No. CF-AA5713A)].
Expansion Bus Connector
24-pin
USB Port
USB 2.0 × 2 / USB 3.0 × 2
LAN Port
RJ-45 × 1
HDMI Port
HDMI × 1 For exclusive use with HDMI standard
VGA Port
Mini Dsub 15-pin female (Analog interface)
Serial Port
Dsub 9-pin male
Physical Dimensions
Approx. 400 mm × 55 mm × 290 mm, (Width × Height × Depth) {15.8" × 2.2" × 11.5"}
Weight Approx.
2.0 kg {4.5 lb.}
- Panasonic CF-VEB541U - port replicator - VGA, HDMI
- Product Type
- Port replicator
- Video Interfaces
- VGA, HDMI
- Designed For
- Panasonic Toughbook 54 (Mk1)
- Product Type
- Port replicator
- 1 x serial - RS-232 - 9 pin D-Sub (DB-9) , 2 x USB 2.0 - 4 pin USB Type A , 1 x network - RJ-45 , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x display / video - HDMI - 19 pin HDMI Type A
- Designed For
