Panasonic Lumix DMC-LS6 - Digital camera - compact - 14.1 Mpix - 5 x optical zoom - black
Quicklinx: 825DWS00 Mfr#: DMC-LS6E-K
  • SDHC Memory Card
The DMC-LS6 features a 5x optical zoom lens from 26 mm wide-angle. The 26 mm wide-angle lens captures larger viewing space compared with that of standard 35 mm camera, which comes in handy when shooting vast landscapes or many subjects at short distance indoor.
The DMC-LS6 features a 14.1-megapixel high-resolution CCD. Combined with the Venus engine, 14.1-megapixel CCD sensor enables the recording of beautiful photos and high-definition videos with higher quality signal processing.
  • Optical image stabilizer for suppressing hand-shake blur
    The optical image stabilizer compensates for blurring caused by hand-shake. Apart from the digital image correction, the optical image stabilizer corrects a jolt of light axis by shifting the lens unit to offset it. Thus the image is not affected digitally nor deteriorated at all. The optical image stabilizer lets you shoot in dimly lit rooms or evening illumination without losing the mood It also works for macro shots and zoom shots, which are especially susceptible to hand-shake.
  • 5x optical zoom lens from 26 mm wide-angle
  • 14.1-megapixel CCD sensor
  • iA (Intelligent Auto) mode for one-press beauty
    In the iA mode, 3 detection functions work automatically and simultaneously to optimize users settings, making it easier than ever to take beautiful photos every time. The iA mode includes the Optical image stabilizer to detect hand-shake, face detection AF/AE to detect faces in the frame and adjust the brightness of the face properly, and intelligent scene selector to detect scene conditions. The face detection AF/AE also features the digital red-eye correction (red-eye removal).
  • 2.7-inch, 230,000-dot LCD
    The DMC-LS6 can record motion pictures in high-definition (1,280 x 720 pixels in motion JPEG format). The DMC-LS6's 2.7-inch, 230,000-dot LCD reflects fine details, making it easy to check the focus before shooting. It also serves as a small photo and video viewer, allowing you and friends to enjoy viewing the still and motion images together.
Panasonic Lumix DMC-LS6 - digital camera
Digital camera - 720p - compact
Memory Card Slot
SD card
Internal Storage
10 MB
Sensor Resolution
14.1 Megapixel
Max Video Resolution
1280 x 720
Lens System
Zoom lens - 5x zoom - 4.7 - 23.5 mm - f/2.8-6.5
Focus Adjustment
Automatic
Min Focus Distance
15 cm
Digital Zoom
4x
Image Stabiliser
Optical
Camera Flash
Built-in flash
Display
LCD display - 2.7"
Supported Battery
2 x AA alkaline battery (included) , AA NiMH rechargeable battery (optional)
USB 2.0
9.7 cm x 2.7 cm x 6.2 cm
125 g
Enclosure Colour
Sensor Resolution
14.1 Megapixel
Optical Sensor Type
CCD
Total Pixels
14,500,000 pixels
Effective Sensor Resolution
14,100,000 pixels
Optical Sensor Size
1/2.33"
ISO (Max)
6400
Optical Zoom
5x
Digital Zoom
4x
Image Stabiliser
Optical
Built-in Optical Image Stabiliser
Face Detection
Print Standard
Direct print, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
9
Face Detection
Face Detection AF/AE
Digital Video Format
QuickTime, MJPEG
Image Recording Format
JPEG
1280 x 720
USB 2.0
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO auto, ISO auto (1600-6400)
Exposure Metering
Multi-segment
Exposure Modes
Programme, automatic
Shooting Programs
Portrait mode, party/indoor, night portrait, self-portrait, scenery, food, fireworks, panorama assist, night scene, sports mode, sunset, beach, snow, high sensitivity, baby
Special Effects
Black & White, Sepia, Vivid
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, cloudy, daylight, shade
Max Shutter Speed
1/2000 sec
Min Shutter Speed
8 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Focal Length Equivalent to 35mm Camera
26 - 130mm
Focus Adjustment
Automatic
Min Focus Distance
15 cm
Zoom Adjustment
Motorised drive
Lens Construction
5 groups / 7 elements
Built-in lens shield, aspherical lens
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
Effective Flash Range
0.6 m - 4.6 m: ISO auto (wide lens) , 0.6 m - 2 m: ISO auto (tele lens)
Additional Features
Continuous Shooting Speed
0.8 frames per second
Self-Timer Delay
10 sec, 2sec
Additional Features
Built-in speaker, RGB primary colour filter, in-camera red-eye removal, resizing an image, Scene Detection Technology, Intelligent Scene Selector, face detection, Intelligent Auto (iA), text stamp
Display
2.7" LCD display
Display Format
230,000 pixels
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0
Software
Software
Drivers & Utilities, Adobe Reader, Panasonic PHOTOfunSTUDIO 6.0
Hand strap, USB cable
Battery Type
AA - Alkaline - standard form factor
Details
Battery Life Details
Photo shooting - 160 shots (alkaline batteries) , Photo shooting - 320 shots (NiMH batteries (1950mAh))
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Internal Storage
10 MB
Image Storage
JPEG 4320 x 3240 , JPEG 4320 x 2880 , JPEG 4320 x 2432 , JPEG 3648 x 2736 , JPEG 2560 x 1920 , JPEG 2048 x 1536 , JPEG 640 x 480
Video Capture
MJPEG - 1280 x 720 - 30 fps , MJPEG - 640 x 480 - 30 fps , MJPEG - 320 x 240 - 30 fps
9.7 cm
2.7 cm
6.2 cm
125 g
