This Panasonic scanner features flatbed scanning for scanning passports, datebooks, and other special documents. The scanner is also equipped with a Start button, so work efficiency can be increased by quickly scanning while turning the book's pages, with no PC operation necessary. You can also use its flatbed to scan 2-page spreads from books, magazines, etc., and automatically divide the single image into two sheets. Dividing scanned documents saves time and trouble because it makes complex editing operations unnecessary. Finally, save time by reducing the number of scans with Multi-Crop - place various-sized documents on the flatbed and scan them all at once, then crop whatever parts you need. This is convenient for scanning multiple business cards and thick documents.
Flatbed scanning for scanning passports, datebooks, and other special documents
Passports, date books, bound materials and other documents that cannot be fed through the Auto Document Feeder (ADF) can be scanned with flatbed scanning. The scanner is also equipped with a Start button, so work efficiency can be increased by quickly scanning while turning the book's pages, with no PC operation necessary. -
Easily get the data you need from each page with page separation
Use the flatbed to scan 2-page spreads from books, magazines, etc., and automatically divide the single image into two sheets. Dividing scanned documents saves time and trouble because it makes complex editing operations unnecessary. -
Save time by reducing the number of scans with Multi-Crop
Place various-sized documents on the flatbed and scan them all at once, then crop whatever parts you need. This is convenient for scanning multiple business cards and thick documents.
 - Panasonic KV-SS081-U - flatbed scanner - desktop - USB 2.0
 - Flatbed scanner - desktop
- Interface Type
 - USB 2.0
- Scanning Sensor Type
 - Contact Image Sensor (CIS)
- Max Supported Document Size
 - 216 x 297 mm
- Input Type
- Optical Resolution
 - 600 dpi x 600 dpi
- Scan Speed
 - 3 sec / page
- Max Document Size
 - 216 mm x 297 mm
- Document Feeder Type
 - Manual
- Power
 - AC 120/230 V (50/60 Hz)
 - 41 cm x 30.9 cm x 5.4 cm
 - 2.5 kg
- Interface Type
 - USB 2.0
 - 216 x 297 mm
Scanner
- Input Type
 - 600 dpi x 600 dpi
- Scan Speed
 - 3 sec / page
- Scanner Speed Details
 - 3 sec/scan - colour - A4 - 300 dpi , 3 sec/scan - black & white - A4 - 300 dpi
- Scanner Features
 - 2-Page Separation, Multi-Crop
Media Handling
- Max Document Size
 - 216 mm x 297 mm
 - Manual
- Interfaces Details
 - USB 2.0
- Cables Included
 - 1 x USB cable
- Voltage Required
- Power Consumption Operational (Standby)
 - 8 Watt
- Power Consumption Stand by
 - 2 Watt
- Power Consumption Sleep
 - 2 Watt
 - 41 cm
 - 30.9 cm
 - 5.4 cm
 - 2.5 kg
 - 10 °C
 - 35 °C
 - 20 - 80%
