Panasonic KV-S7075C Document Scanner
Quicklinx: 9KYMWS00 Mfr#: KV-S7075C-U
Panasonic KV-S7075C is a high-speed color flatbed document scanner with ADF.
Now you can consecutively scan ADF and flatbed documents in one simple operation, greatly improving your productivity.
Place various sized documents on the flatbed, such as checks, ID cards, and business cards, and the KV-S7075C will scan them in one pass and produce multiple individually cropped images!
Documents of different sizes and thicknesses can be difficult to scan, especially when they are part of the same batch. The KV-S7075C can accommodate them all at once thanks to it's ability to left, right or center justify the scan guides.
As with Panasonic's other award-winning document scanners, the KV-S7075C supports a variety of image enhancement functions built right into it. Auto-crop, dynamic thresholding, auto/binary distinction, blank paper removal, hole removal and multi-color dropout are just a few of the available features found on every Panasonic document scanner.
Panasonic KV-S7075C - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Max Supported Document Size
A3 (297 x 420 mm)
Europe
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
95 ppm (mono) / 95 ppm (colour)
Max Document Size
302 mm x 2540 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
200 sheets
Duty Cycle
15000 scans per day
AC 230V (50/60 Hz)
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP 32-bit
75.5 cm x 50.8 cm x 28.9 cm
29 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
A3 (297 x 420 mm)
Europe
Scanner
Input Type
Grayscale Depth
Colour Depth
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Max Document Scan Speed B/W
95 ppm
Max Document Scan Speed Colour
95 ppm
Duty Cycle
15000 scans per day
Scanner Speed Details
75 ppm - portrait B&W - A4 - 200 dpi , 150 ipm - duplex - portrait B&W - A4 - 200 dpi , 95 ppm - landscape B&W - A4 - 200 dpi , 190 ipm - duplex - landscape B&W - A4 - 200 dpi , 75 ppm - portrait colour - A4 - 200 dpi , 150 ipm - duplex - portrait colour - A4 - 200 dpi , 95 ppm - landscape colour - A4 - 200 dpi , 190 ipm - duplex - landscape colour - A4 - 200 dpi
Scanner Features
Ultrasonic Double Feed Detection, Double Exposure, Blank Page Removal, Automatic Binary / Color Distinction, Auto Crop, Auto Deskew, Smooth Background
TWAIN, ISIS
Media Handling
Max Document Size
302 mm x 2540 mm
Plain paper
Supported Document Size Details
Flatbed - up to 297 x 432 mm , ADF - up to 302 x 2540 mm
Automatic
200 sheets
USB 2.0 - Type B
Blower, roller cleaning paper, shading paper
1 x USB cable
ENERGY STAR Certified
Internal power supply
AC 230V (50/60 Hz)
Software Included
Drivers & Utilities, QuickScan Pro (Demo), Image Capture Plus
75.5 cm
50.8 cm
28.9 cm
29 kg
10 °C
35 °C
30 - 80%
