Boost your business efficiency with an A3-size, high speed document scanner. The fast 90 ppm scan speed and 200-page automatic document feeder of the KV-S5055C make it ideal for both large-volume and distributed scanning environments. Panasonic's unique paper feed mechanism also minimizes the possibility of damaging important documents and ensures precise feeding to make your office work even more efficient.
Stapled document detection
Multiple sensors are used to detect various types of stapled documents, and to immediately stop the scanner when a stapled document is detected. This minimizes damage to both the document and the optical glass. -
Ultrasonic double feed detection
The KV-S5055C is equipped with an ultrasonic double feed detection sensor, which accurately detects double feeding even when scanning documents of various thicknesses. -
Double feed skip key
Sometimes when double-fed documents are mis-detected due to affixed labels or thicker paper. In this case, simply press the double feed skip key on the control panel and the unit will continue scanning. -
Ionizer
The ion-filled breeze created by the ionizer neutralizes the electrical charge on the documents being scanned and reduces the amount of paper dust that clings to the surface of the optical glass. -
Scanning glass cleaning brush
This brush directly cleans the scan glass to help reduce the amount of paper dust accumulation. This process, along with the Ionizer, helps to reduce the amount of maintenance necessary.
- Panasonic KV-S5055C - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CCD
- Max Supported Document Size
- A3 (297 x 420 mm)
- Localisation
- Europe
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 90 ppm (mono) / 90 ppm (colour)
- Max Document Size
- 305 mm x 2540 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, business card, check
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 200 sheets
- Duty Cycle
- 15000 scans per day
- Power
- AC 230V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows XP 32-bit
- 46.8 cm x 44.4 cm x 33.9 cm
- 18 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- A3 (297 x 420 mm)
- Localisation
- Europe
Scanner
- Input Type
- Grayscale Depth
- 600 dpi x 600 dpi
- CCD
- Max Document Scan Speed B/W
- 90 ppm
- Max Document Scan Speed Colour
- 90 ppm
- Duty Cycle
- Scanner Speed Details
- 70 ppm - portrait B&W - A4 - 200 dpi , 140 ipm - duplex - portrait B&W - A4 - 200 dpi , 90 ppm - landscape B&W - A4 - 200 dpi , 180 ipm - duplex - landscape B&W - A4 - 200 dpi , 70 ppm - portrait colour - A4 - 200 dpi , 140 ipm - duplex - portrait colour - A4 - 200 dpi , 90 ppm - landscape colour - A4 - 200 dpi , 180 ipm - duplex - landscape colour - A4 - 200 dpi , 50 ppm - portrait B&W - A4 - 300 dpi , 100 ipm - duplex - portrait B&W - A4 - 300 dpi , 60 ppm - landscape B&W - A4 - 300 dpi , 120 ipm - duplex - landscape B&W - A4 - 300 dpi , 50 ppm - portrait colour - A4 - 300 dpi , 100 ipm - duplex - portrait colour - A4 - 300 dpi , 60 ppm - landscape colour - A4 - 300 dpi , 120 ipm - duplex - landscape colour - A4 - 300 dpi
- Scanner Features
- Ultrasonic Double Feed Detection, Double Exposure, Blank Page Removal, Automatic Binary / Color Distinction, Auto Crop, Auto Deskew, Smooth Background
- TWAIN, ISIS
Media Handling
- Max Document Size
- 305 mm x 2540 mm
- Automatic
- 200 sheets
- Interfaces Details
- USB 2.0
- Included Accessories
- Blower, roller cleaning paper, shading paper
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- Software Included
- Drivers & Utilities, Image Capture Plus
- OS Required
- 46.8 cm
- 44.4 cm
- 33.9 cm
- 18 kg
- 10 °C
- 35 °C
- 20 - 80%
