Panasonic KV-S4065CW Document Scanner
Quicklinx: 9KYPWS00 Mfr#: KV-S4065CW-U
Panasonic's ToughFeed paper feed mechanism makes the Panasonic KV-S4065CW the solution to your document scanning needs. The Stapled Document Detection virtually eliminates stapled documents from being fed, the double-feed prevention system employs an ultrasonic sensor that detects the double feeding or originals during scanning and the Load Detection circuit allows the document hopper to automatically adjust its position to ensure reliable paper feeding. This innovative design has been proven effective even when the documents being scanned contain a mix of paper of different weights or thickness. Thanks to ToughFeed, optimum reliability is assured even when scanning high-volume documents.
Despite a compact desktop design, the KV-S4065CW features a rugged, high durability design and reliable paper handling. With up to a 30,000 page per day scanning duty cycle that's at the top of its class, this versatile high-speed scanner provides the extra performance required for heavy scanning demands, easily handling a wide range of paper weights from 5.5lbs to 55.6 lbs.
Panasonic KV-S4065CW - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Max Supported Document Size
297 x 432 mm
Input Type
Optical Resolution
600 dpi
Max Document Scan Speed
80 ppm (mono) / 80 ppm (colour)
Automatic Duplexing
Document Feeder Type
Automatic
Document Storage Capacity
300 sheets
47.4 cm x 58.5 cm x 32.9 cm
25 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
297 x 432 mm
Scanner
Input Type
Optical Resolution
600 dpi
Automatic Duplexing
Max Document Scan Speed B/W
80 ppm
Max Document Scan Speed Colour
80 ppm
Scanner Speed Details
60 ppm - portrait B&W - A4 - 200 dpi , 120 ipm - duplex - portrait B&W - A4 - 200 dpi , 60 ppm - portrait colour - A4 - 200 dpi , 120 ipm - duplex - portrait colour - A4 - 200 dpi , 80 ppm - landscape B&W - A4 - 200 dpi , 160 ipm - duplex - landscape B&W - A4 - 200 dpi , 80 ppm - landscape colour - A4 - 200 dpi , 160 ipm - duplex - landscape colour - A4 - 200 dpi
Scanner Features
Color Dropout, Ultrasonic Double Feed Detection
TWAIN, ISIS
Media Handling
Automatic
300 sheets
Interfaces Details
USB 2.0
1 x USB cable
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
(4 Watt)
Software Included
Drivers & Utilities, QuickScan Pro (Demo), RTIV
47.4 cm
58.5 cm
32.9 cm
25 kg
15 °C
30 °C
20 - 80%
