The KV-S1015C is a scanner designed for the small or home office, or alternatively a desktop set-up in the business market. The scanner is very compact, yet professional and delivers high quality images up to 600 dpi. It also features Cloud services giving a high level of 'workgroup' productivity and a scanning speed of 20 pages per minute; making it one of the faster compact scanners in the industry.
Many smaller businesses have delayed investing in paperless office projects, however the KV-S1015C will enable businesses to afford a scanner and facilitate the scanning of incoming post, invoices, and payroll and purchasing receipts in order to automate the administration processes, reduce business costs, secure the billing process and ultimately improve business productivity.
- Panasonic KV-S1015C-U - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Max Supported Document Size
- 216 x 2540 mm
- Input Type
- Optical Resolution
- 600 dpi
- Max Document Scan Speed
- 20 ppm (mono) / 20 ppm (colour)
- Max Document Size
- 216 mm x 2540 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 7, Microsoft Windows XP SP3 or later, Microsoft Windows Vista (32/64 bits) SP2 or later, Windows 8 (32/64 bits)
- 30.3 cm x 17.7 cm x 13.7 cm
- 2.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 216 x 2540 mm
Scanner
- Input Type
- 600 dpi
- Max Document Scan Speed B/W
- 20 ppm
- Max Document Scan Speed Colour
- 20 ppm
- Scanner Speed Details
- 20 ppm - portrait B&W - A4 - 200 dpi , 40 ipm - duplex - portrait B&W - A4 - 200 dpi , 20 ppm - portrait colour - A4 - 200 dpi , 40 ipm - duplex - portrait colour - A4 - 200 dpi
- Scanner Features
- Double Exposure, Gamma Correction, Automatic Separation, Noise Reduction, Shadow Removal, Mirror Image, Dynamic Threshold, Blank Page Removal, automatic colour detection, Smooth Background
- TWAIN, ISIS
Media Handling
- Max Document Size
- 216 mm x 2540 mm
- Plain paper
- Automatic
- 50 sheets
- Interfaces Details
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 17 Watt (4.5 Watt)
- Software Included
- Drivers & Utilities, Image Capture Plus, Presto! BizCard 6, Presto! PageManager 9
- OS Required
- 30.3 cm
- 17.7 cm
- 13.7 cm
- 2.7 kg
- 10 °C
- 35 °C
- 20 - 80%
