Panasonic HDC-SD700 Full HD Camcorder
Quicklinx: 6N1GWS00 Mfr#: HDC-SD700EBK
  • SDHC Memory Card
The SD700's high-sensitivity 3MOS system has achieved 11.49 million effective motion image pixels. This image sensor offers beautiful images with significantly better color quality, detail and gradation than the 1MOS sensor system. The large-diameter F1.5 Leica Dicomar lens Crystal Engine Pro and this high-sensitivity sensor have improved the efficiency of light gathering, increased sensitivity, and reduced noise by one-half to provide users with bright, low-noise recording even in dim lighting.
The 1080/50p recording conveys about twice the information of 1080i recording to produce the ultimate beauty in image quality, exceeding even conventional Full-HD images. It minimizes afterimages and flickering caused by subject motion and renders crisp, detailed images.
The O.I.S. (Optical Image Stabilizer), which uses gyrosensors to detect hand-shake and moves a corrective lens to adjust the optical axis and eliminate blurring, has further evolved. While the conventional O.I.S. system could not sufficiently eliminate low-frequency hand-shake, the Power O.I.S. is able to correct it about five times more effectively. The O.I.S. also features an Active mode to assure clear, beautiful images across the entire range from wide angle to telephoto.
The 12x optical zoom lens is further enhanced by Intelligent Resolution technology in the Crystal Engine Pro image-processing circuit, to produce the 20x intelligent zoom. The zoom achieves even greater image detail.
The iA function includes face recognition feature that recognizes the faces of previously registered subjects, and automatically optimizes the focus and exposure for those special people. It continues to track the subject as he or she moves anywhere within the LCD frame, making it ideal for video shooting. It is extremely useful for capturing someone's face in a group. Names can also be registered and displayed on the LCD while shooting. A total of six people can be registered, and up to three people at a time can be detected when shooting.
Panasonic HDC-SD700EBK - camcorder - Leica - storage: flash card
Camcorder - 1080p
Lens Included
Leica
Media Type
Flash card
Memory Card Slot
SD card
Sensor Resolution
3.05 MP
Effective Sensor Resolution
Video: 2.53 MP - Photo: 2.63 MP
Lens System
Zoom lens - 12x zoom - 3.45 - 41.4 mm - f/1.5-2.8
Focus Adjustment
Automatic, manual
Digital Zoom
700x
Image Stabiliser
Optical (POWER O.I.S.)
Camera Flash
Built-in flash
Viewfinder
Electronic - colour - LCD
Display
LCD display - 3"
Supported Battery
Li-ion rechargeable battery - 1250 mAh (included)
Composite video/audio, HDMI, USB 2.0
6.6 cm x 13.8 cm x 6.9 cm
375 g
Camcorder - 1080p
Lens Included
Leica
Enclosure Colour
Camcorder Type
Consumer
Camcorder Sensor Resolution
3.05 MP
Sensor Qty
3 MOS
Effective Video Resolution
2.53 MP
Effective Photo Resolution
2.63 MP
Camcorder Interpolated Photo Resolution
14.2 MP
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
3MOS
Optical Sensor Size
1/4.1"
Optical Zoom
12x
Digital Zoom
700x
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Surround Sound
Dolby Digital 5.1 channel recording, Dolby Digital AC-3 (2 channel) recording
Print Standard
DPOF support, PictBridge support
Auto Focus
TTL contrast detection
Digital Video Format
AVCHD
Image Recording Format
JPEG
Exposure & White Balance
Min Illumination
1 lux
Exposure Modes
Programme, automatic, aperture-priority, shutter-priority
White Balance
Custom, automatic, presets
White Balance Presets
Cloudy, sunlight, indoor
Max Shutter Speed
1/8000 sec
Min Shutter Speed
1/2 sec
Lens System
Leica zoom lens - 12x zoom - 3.45 - 41.4 mm - f/1.5-2.8
Focal Length Equivalent to 35mm Camera
35 - 420mm
Focus Adjustment
Automatic, manual
Zoom Adjustment
Motorised drive
Filter Size
46 mm
Built-in lens shield
Camera Flash
Camera Flash
Built-in flash
Additional Features
Low Lux / Night Mode
Additional Features
Built-in speaker, Backlight Compensation (BLC), histogram display, Scene Detection Technology, Intelligent Scene Selector, interval shooting mode, takes photos while film recording, AF/AE tracking, Intelligent Contrast Control, Pre-Rec function, Auto Ground-Directional Standby (AGS), Intelligent Resolution Technology, face detection, built-in help guide, 25p Cinema Mode, Smile Detection technology, automatic display brightness adjustment, Face Recognition
Viewfinder
Viewfinder Type
Electronic - LCD
Viewfinder Colour Support
Display
3" LCD display
Display Format
230,400 pixels
Display Form Factor
Rotating
Touch Screen
Microphone
Microphone Operation Mode
Surround
Microphone Features
Zoom, wind noise reduction
Connector Type
HDMI output , USB , Component video output , Composite video/audio output , Microphone , Headphones
Software
Software
Drivers & Utilities, Panasonic HD Writer AE 2.1
Lens hood, stylus, power adapter, accessory shoe adaptor, USB cable, audio / video cable, component video cable, IR remote control
Battery Type
Lithium Ion - manufacturer-specific
Details
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 4864 x 2736 , JPEG 3840 x 2160 , JPEG 1920 x 1080 , JPEG 4608 x 3072 , JPEG 3600 x 2400 , JPEG 2880 x 1920 , JPEG 3072 x 1728 , JPEG 4032 x 3024 , JPEG 3200 x 2400 , JPEG 2560 x 1920 , JPEG 640 x 480
6.6 cm
13.8 cm
6.9 cm
375 g
