The SD700's high-sensitivity 3MOS system has achieved 11.49 million effective motion image pixels. This image sensor offers beautiful images with significantly better color quality, detail and gradation than the 1MOS sensor system. The large-diameter F1.5 Leica Dicomar lens Crystal Engine Pro and this high-sensitivity sensor have improved the efficiency of light gathering, increased sensitivity, and reduced noise by one-half to provide users with bright, low-noise recording even in dim lighting.
The 1080/50p recording conveys about twice the information of 1080i recording to produce the ultimate beauty in image quality, exceeding even conventional Full-HD images. It minimizes afterimages and flickering caused by subject motion and renders crisp, detailed images.
The O.I.S. (Optical Image Stabilizer), which uses gyrosensors to detect hand-shake and moves a corrective lens to adjust the optical axis and eliminate blurring, has further evolved. While the conventional O.I.S. system could not sufficiently eliminate low-frequency hand-shake, the Power O.I.S. is able to correct it about five times more effectively. The O.I.S. also features an Active mode to assure clear, beautiful images across the entire range from wide angle to telephoto.
The 12x optical zoom lens is further enhanced by Intelligent Resolution technology in the Crystal Engine Pro image-processing circuit, to produce the 20x intelligent zoom. The zoom achieves even greater image detail.
The iA function includes face recognition feature that recognizes the faces of previously registered subjects, and automatically optimizes the focus and exposure for those special people. It continues to track the subject as he or she moves anywhere within the LCD frame, making it ideal for video shooting. It is extremely useful for capturing someone's face in a group. Names can also be registered and displayed on the LCD while shooting. A total of six people can be registered, and up to three people at a time can be detected when shooting.
- Panasonic HDC-SD700EBK - camcorder - Leica - storage: flash card
- Product Type
- Camcorder - 1080p
- Lens Included
- Leica
- Media Type
- Flash card
- Memory Card Slot
- SD card
- Sensor Resolution
- 3.05 MP
- Effective Sensor Resolution
- Video: 2.53 MP - Photo: 2.63 MP
- Lens System
- Zoom lens - 12x zoom - 3.45 - 41.4 mm - f/1.5-2.8
- Focus Adjustment
- Automatic, manual
- Digital Zoom
- 700x
- Image Stabiliser
- Optical (POWER O.I.S.)
- Camera Flash
- Built-in flash
- Viewfinder
- Electronic - colour - LCD
- Display
- LCD display - 3"
- Supported Battery
- Li-ion rechargeable battery - 1250 mAh (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Black
- 6.6 cm x 13.8 cm x 6.9 cm
- 375 g
- Product Type
- Camcorder - 1080p
- Lens Included
- Leica
- Enclosure Colour
- Black
- Camcorder Type
- Consumer
- Camcorder Sensor Resolution
- 3.05 MP
- Sensor Qty
- 3 MOS
- Effective Video Resolution
- 2.53 MP
- Effective Photo Resolution
- 2.63 MP
- Camcorder Interpolated Photo Resolution
- 14.2 MP
- Widescreen Video Capture
- Camcorder Media Type
- Flash card
- Optical Sensor Type
- 3MOS
- Optical Sensor Size
- 1/4.1"
- Optical Zoom
- 12x
- Digital Zoom
- 700x
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Surround Sound
- Dolby Digital 5.1 channel recording, Dolby Digital AC-3 (2 channel) recording
- Print Standard
- DPOF support, PictBridge support
- Auto Focus
- TTL contrast detection
- Digital Video Format
- AVCHD
- Image Recording Format
- JPEG
- Interface
Exposure & White Balance
- Min Illumination
- 1 lux
- Exposure Modes
- Programme, automatic, aperture-priority, shutter-priority
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Cloudy, sunlight, indoor
- Max Shutter Speed
- 1/8000 sec
- Min Shutter Speed
- 1/2 sec
Lens System
- Leica zoom lens - 12x zoom - 3.45 - 41.4 mm - f/1.5-2.8
- Focal Length Equivalent to 35mm Camera
- 35 - 420mm
- Focus Adjustment
- Automatic, manual
- Zoom Adjustment
- Motorised drive
- Filter Size
- 46 mm
- Built-in lens shield
Camera Flash
- Camera Flash
- Built-in flash
Additional Features
- Low Lux / Night Mode
- Additional Features
- Built-in speaker, Backlight Compensation (BLC), histogram display, Scene Detection Technology, Intelligent Scene Selector, interval shooting mode, takes photos while film recording, AF/AE tracking, Intelligent Contrast Control, Pre-Rec function, Auto Ground-Directional Standby (AGS), Intelligent Resolution Technology, face detection, built-in help guide, 25p Cinema Mode, Smile Detection technology, automatic display brightness adjustment, Face Recognition
Viewfinder
- Viewfinder Type
- Electronic - LCD
- Viewfinder Colour Support
Display
- 3" LCD display
- Display Format
- 230,400 pixels
- Display Form Factor
- Rotating
- Touch Screen
Microphone
- Microphone Operation Mode
- Surround
- Microphone Features
- Zoom, wind noise reduction
- Connector Type
- HDMI output , USB , Component video output , Composite video/audio output , Microphone , Headphones
Software
- Software
- Drivers & Utilities, Panasonic HD Writer AE 2.1
- Included Accessories
- Lens hood, stylus, power adapter, accessory shoe adaptor, USB cable, audio / video cable, component video cable, IR remote control
- Battery Type
- Lithium Ion - manufacturer-specific
- Details
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Image Storage
- JPEG 4864 x 2736 , JPEG 3840 x 2160 , JPEG 1920 x 1080 , JPEG 4608 x 3072 , JPEG 3600 x 2400 , JPEG 2880 x 1920 , JPEG 3072 x 1728 , JPEG 4032 x 3024 , JPEG 3200 x 2400 , JPEG 2560 x 1920 , JPEG 640 x 480
- 6.6 cm
- 13.8 cm
- 6.9 cm
- 375 g
- 0 °C
- 40 °C
