Panasonic HC-V770 Camcorder - Black
Quicklinx: BMR4WS00 Mfr#: HC-V770EB-K
Type: Camcorder
Media Type: Flash card
Optical Zoom: 20
Video Input: HDMI, USB 2.0
HD Support: [N/A]
£261.74 ex VAT
£314.08 inc VAT
Catch the scenes you want with easy zooming and excellent quality. Use the HDR (High Dynamic Range) Movie technology to get clear shots even with backlighting. And take sub camera shots with a smartphone.
  • Premium picture quality with advanced lens, sensor and engine
    The lens system drives each of four lens groups separately, reducing the drive ranges to result in high image quality, high-powered zooming, and a compact camera body.
  • HDR movie clear shots with excellent detail in both bright and dark areas
    By combining two images taken with different exposure times, the HDR Movie function suppresses blown highlights and blocked shadows for crisper, clearer videos. This is the world's first' consumer camcorder to feature the HDR Movie function. Even in difficult shooting situations, such as backlighting, you can easily capture natural videos with excellent gradation.
  • Wireless twin camera
    Using your smartphone with Wi-Fi operation as a sub camera, you can shoot from two angles at the same time. Since you are shooting with different cameras, you can use one at a distance, or at any angle you choose.
  • 20x optical zoom with 4-drive lens system
    By driving each of four lens groups separately, the drive ranges are reduced, resulting in high image quality, high- powered zooming, and a compact camera body. This keeps the body compact even with a 20x optical zoom.
  • BSI Sensor
    The Back Side Illumination Sensor has a large effective area with 6.03M effective pixels, suppressing noise even when shooting in dimly lit places, such as indoor scenes or nightscapes. It achieves stunningly beautiful images even down to the tiniest details.
  • Crystal Engine
    Panasonic's unique, high-speed engine lets you shoot and play smooth Slow Motion Video in Full HD. Its noise reduction function reduces noise for crisp, vibrantly colorful Full HD images.
  • Level shot function 5-axis HYBRID O.I.S. +
    The Level Shot function automatically detects and corrects the tilting of captured images. The setting can be adjusted to one of three levels depending on the shooting conditions.
  • Full HD slow motion video
    Records Full HD (1920x1080) at 120 fps. And the Intelligent Frame Creation of the Crystal Engine interpolates to an equivalent of 240 fps,' for smooth slow motion. Switches to slow motion while you touch the icon on the LCD screen during shooting.
Panasonic HC-V770 - camcorder - storage: flash card
Camcorder - 1080p
Media Type
Flash card
Memory Card Slot
SD card
Image Processor
Crystal Engine PRO+
Wireless Interface
Wi-Fi, NFC
Sensor Resolution
12.76 MP
Effective Sensor Resolution
Video: 6.03 MP - Photo: 6.03 MP
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 20x zoom - 4.08 - 81.6 mm - f/1.8-3.6
Focus Adjustment
Automatic, manual
Digital Zoom
1500x
Image Stabiliser
Optical (5-axis HYBRID O.I.S. +)
Camera Flash
Camcorder flash light
Display
LCD display - 3"
Supported Battery
Li-ion rechargeable battery - 1940 mAh (included)
HDMI, USB 2.0
6.5 cm x 13.9 cm x 7.3 cm
353 g
Camcorder - 1080p
Built-in Light
IR illuminator
Enclosure Colour
Camcorder Type
Consumer
Camcorder Sensor Resolution
12.76 MP
Sensor Qty
1 MOS
Effective Video Resolution
6.03 MP
Effective Photo Resolution
6.03 MP
Camcorder Interpolated Photo Resolution
24.0 MP
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
BSI MOS
Optical Sensor Size
1/2.3"
Optical Zoom
20x
Digital Zoom
1500x
Video Recording Modes
HA, HG, HE, PH
Image Processor
Crystal Engine PRO+
Image Stabiliser
Built-in Optical Image Stabiliser
HDR Mode
Auto HDR mode
Surround Sound
Dolby Digital 5.1 channel recording, Dolby Digital AC-3 (2 channel) recording
Print Standard
Exif Print support
Auto Focus
TTL contrast detection
Digital Video Format
AVCHD, H.264, iFrame
Image Recording Format
JPEG
1920 x 1080
HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
Connectivity Features
Remote control via mobile devices, remote live view
Exposure & White Balance
Min Illumination
1 lux
Exposure Modes
Programme, automatic
Special Effects
Miniature, 8mm Movie, Silent Movie
White Balance
Custom, automatic, presets
White Balance Presets
Cloudy, sunlight, indoor
Max Shutter Speed
1/8000 sec
Min Shutter Speed
1/25 sec
Lens System
Focal Length Equivalent to 35mm Camera
29.5 - 612mm
Focus Adjustment
Automatic, manual
Zoom Adjustment
Motorised drive
Filter Size
49 mm
Built-in lens shield, 4-Drive Lens System
Camera Flash
Camera Flash
Additional Features
Built-in Light
Low Lux / Night Mode
Additional Features
Built-in speaker, takes photos while film recording, USB charging, Intelligent Auto (iA), Time-Lapse recording, Level Shot Function, Creative Control, Twin Camera function, Baby Monitor mode
Display
3" LCD display
Display Format
460,800 pixels
Display Form Factor
Rotating
Touch Screen
Microphone
Microphone Operation Mode
Surround
Microphone Features
Zoom, wind noise reduction
Connector Type
HDMI output (19 pin micro HDMI Type D) , USB 2.0 , Microphone (mini-phone stereo 3.5 mm) , Headphones (mini-phone stereo 3.5 mm) , Accessory shoe
Software
Software
Drivers & Utilities, Panasonic HD Writer AE 5.2
AC power adaptor, accessory shoe adaptor, USB cable, HDMI cable
Battery Type
Lithium Ion - manufacturer-specific
Details
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Memory Card Included
No
Image Storage
JPEG 1920 x 1080 , JPEG 4736 x 2664 , JPEG 6528 x 3672 , JPEG 5472 x 3648 , JPEG 3984 x 2656 , JPEG 1728 x 1152 , JPEG 4896 x 3672 , JPEG 3264 x 2448 , JPEG 640 x 480
Video Capture
AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1920 x 1080 - 50 fps - 13Mbps , AVCHD - 1920 x 1080 - 50 fps - 9Mbps , H.264 - 1920 x 1080 - 50Mbps , H.264 - 1920 x 1080 - 28Mbps , H.264 - 1280 x 720 - 9Mbps , iFrame - 1280 x 720
6.5 cm
13.9 cm
7.3 cm
353 g
Type: Camcorder
Optical Zoom: 20
Video Input: HDMI
Video Input: USB 2.0
HD Support: [N/A]
Brand: Panasonic
