Catch the scenes you want with easy zooming and excellent quality. Use the HDR (High Dynamic Range) Movie technology to get clear shots even with backlighting. And take sub camera shots with a smartphone.
                Premium picture quality with advanced lens, sensor and engineThe lens system drives each of four lens groups separately, reducing the drive ranges to result in high image quality, high-powered zooming, and a compact camera body.
                HDR movie clear shots with excellent detail in both bright and dark areasBy combining two images taken with different exposure times, the HDR Movie function suppresses blown highlights and blocked shadows for crisper, clearer videos. This is the world's first' consumer camcorder to feature the HDR Movie function. Even in difficult shooting situations, such as backlighting, you can easily capture natural videos with excellent gradation.
                Wireless twin cameraUsing your smartphone with Wi-Fi operation as a sub camera, you can shoot from two angles at the same time. Since you are shooting with different cameras, you can use one at a distance, or at any angle you choose.
                20x optical zoom with 4-drive lens systemBy driving each of four lens groups separately, the drive ranges are reduced, resulting in high image quality, high- powered zooming, and a compact camera body. This keeps the body compact even with a 20x optical zoom.
                BSI SensorThe Back Side Illumination Sensor has a large effective area with 6.03M effective pixels, suppressing noise even when shooting in dimly lit places, such as indoor scenes or nightscapes. It achieves stunningly beautiful images even down to the tiniest details.
                Crystal EnginePanasonic's unique, high-speed engine lets you shoot and play smooth Slow Motion Video in Full HD. Its noise reduction function reduces noise for crisp, vibrantly colorful Full HD images.
                Level shot function 5-axis HYBRID O.I.S. +The Level Shot function automatically detects and corrects the tilting of captured images. The setting can be adjusted to one of three levels depending on the shooting conditions.
                Full HD slow motion videoRecords Full HD (1920x1080) at 120 fps. And the Intelligent Frame Creation of the Crystal Engine interpolates to an equivalent of 240 fps,' for smooth slow motion. Switches to slow motion while you touch the icon on the LCD screen during shooting.
- Panasonic HC-V770 - camcorder - storage: flash card
- Product Type
- Camcorder - 1080p
- Media Type
- Flash card
- Memory Card Slot
- SD card
- Image Processor
- Crystal Engine PRO+
- Wireless Interface
- Wi-Fi, NFC
- Sensor Resolution
- 12.76 MP
- Effective Sensor Resolution
- Video: 6.03 MP - Photo: 6.03 MP
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 20x zoom - 4.08 - 81.6 mm - f/1.8-3.6
- Focus Adjustment
- Automatic, manual
- Digital Zoom
- 1500x
- Image Stabiliser
- Optical (5-axis HYBRID O.I.S. +)
- Camera Flash
- Camcorder flash light
- Display
- LCD display - 3"
- Supported Battery
- Li-ion rechargeable battery - 1940 mAh (included)
- Interface
- HDMI, USB 2.0
- Black
- 6.5 cm x 13.9 cm x 7.3 cm
- 353 g
- Product Type
- Camcorder - 1080p
- Built-in Light
- IR illuminator
- Enclosure Colour
- Black
- Camcorder Type
- Consumer
- Camcorder Sensor Resolution
- 12.76 MP
- Sensor Qty
- 1 MOS
- Effective Video Resolution
- 6.03 MP
- Effective Photo Resolution
- 6.03 MP
- Camcorder Interpolated Photo Resolution
- 24.0 MP
- Widescreen Video Capture
- Camcorder Media Type
- Flash card
- Optical Sensor Type
- BSI MOS
- Optical Sensor Size
- 1/2.3"
- Optical Zoom
- 20x
- Digital Zoom
- 1500x
- Video Recording Modes
- HA, HG, HE, PH
- Image Processor
- Image Stabiliser
- Built-in Optical Image Stabiliser
- HDR Mode
- Auto HDR mode
- Surround Sound
- Dolby Digital 5.1 channel recording, Dolby Digital AC-3 (2 channel) recording
- Print Standard
- Exif Print support
- Auto Focus
- TTL contrast detection
- Digital Video Format
- AVCHD, H.264, iFrame
- Image Recording Format
- JPEG
- 1920 x 1080
- Interface
- HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
- Connectivity Features
- Remote control via mobile devices, remote live view
Exposure & White Balance
- Min Illumination
- 1 lux
- Exposure Modes
- Programme, automatic
- Special Effects
- Miniature, 8mm Movie, Silent Movie
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Cloudy, sunlight, indoor
- Max Shutter Speed
- 1/8000 sec
- Min Shutter Speed
- 1/25 sec
Lens System
- Focal Length Equivalent to 35mm Camera
- 29.5 - 612mm
- Focus Adjustment
- Automatic, manual
- Zoom Adjustment
- Motorised drive
- Filter Size
- 49 mm
- Built-in lens shield, 4-Drive Lens System
Camera Flash
- Camera Flash
Additional Features
- Built-in Light
- Low Lux / Night Mode
- Additional Features
- Built-in speaker, takes photos while film recording, USB charging, Intelligent Auto (iA), Time-Lapse recording, Level Shot Function, Creative Control, Twin Camera function, Baby Monitor mode
Display
- 3" LCD display
- Display Format
- 460,800 pixels
- Display Form Factor
- Rotating
- Touch Screen
Microphone
- Microphone Operation Mode
- Surround
- Microphone Features
- Zoom, wind noise reduction
- Connector Type
- HDMI output (19 pin micro HDMI Type D) , USB 2.0 , Microphone (mini-phone stereo 3.5 mm) , Headphones (mini-phone stereo 3.5 mm) , Accessory shoe
Software
- Software
- Drivers & Utilities, Panasonic HD Writer AE 5.2
- Included Accessories
- AC power adaptor, accessory shoe adaptor, USB cable, HDMI cable
- Battery Type
- Lithium Ion - manufacturer-specific
- Details
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Memory Card Included
- No
- Image Storage
- JPEG 1920 x 1080 , JPEG 4736 x 2664 , JPEG 6528 x 3672 , JPEG 5472 x 3648 , JPEG 3984 x 2656 , JPEG 1728 x 1152 , JPEG 4896 x 3672 , JPEG 3264 x 2448 , JPEG 640 x 480
- Video Capture
- AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1920 x 1080 - 50 fps - 13Mbps , AVCHD - 1920 x 1080 - 50 fps - 9Mbps , H.264 - 1920 x 1080 - 50Mbps , H.264 - 1920 x 1080 - 28Mbps , H.264 - 1280 x 720 - 9Mbps , iFrame - 1280 x 720
- 6.5 cm
- 13.9 cm
- 7.3 cm
- 353 g
