Panasonic DMW-LVF2E Live View Finder for Lumix GX1
Quicklinx: 9V6BWS00 Mfr#: DMW-LVF2E
The DMC-GX1 has a large, high-resolution LCD but Panasonic made Live View Finder for finder-enthusiasts. The DMW-LVF2 displays the same information as the LCD when you equip the DMC-GX1 with it. It is effectively used in situations where the LCD is difficult to see, such as under bright sunlight. And it is also handy for low-angle shots because it can be tilted vertically from 0 to 90 degrees.
Panasonic DMW-LVF2 - viewfinder
Accessory Type
Viewfinder
2.9 cm x 4.9 cm x 4.8 cm
36 g
Viewfinder
Electronic
Magnification
1.4x
Diopter Correction
-4 to +4
Lumix DMC-LX7; Lumix G DMC-GX1, DMC-GX1K, DMC-GX1WX, DMC-GX1X, DMC-GX1XV
Accessory Type
Viewfinder
2.9 cm
4.9 cm
4.8 cm
36 g
Accessories
Intended for
Digital camera
Magnification
1.4x
Viewfinder
Viewfinder Type
Electronic
Viewfinder Resolution
1,440,000 pixels
Field of View
100%
Tilting
Diopter Correction
Range
-4 to +4
Panasonic Lumix DMC-LX7 , Panasonic Lumix G DMC-GX1, DMC-GX1K, DMC-GX1WX, DMC-GX1X, DMC-GX1XV
