The DMC-GX1 has a large, high-resolution LCD but Panasonic made Live View Finder for finder-enthusiasts. The DMW-LVF2 displays the same information as the LCD when you equip the DMC-GX1 with it. It is effectively used in situations where the LCD is difficult to see, such as under bright sunlight. And it is also handy for low-angle shots because it can be tilted vertically from 0 to 90 degrees.
- Panasonic DMW-LVF2 - viewfinder
- Accessory Type
- Viewfinder
- 2.9 cm x 4.9 cm x 4.8 cm
- 36 g
- Black
- Viewfinder
- Electronic
- Magnification
- 1.4x
- Diopter Correction
- -4 to +4
- Designed For
- Lumix DMC-LX7; Lumix G DMC-GX1, DMC-GX1K, DMC-GX1WX, DMC-GX1X, DMC-GX1XV
- Accessory Type
- Viewfinder
- 2.9 cm
- 4.9 cm
- 4.8 cm
- 36 g
Accessories
- Intended for
- Digital camera
- Magnification
- 1.4x
Viewfinder
- Viewfinder Type
- Electronic
- Viewfinder Resolution
- 1,440,000 pixels
- Field of View
- 100%
- Tilting
Diopter Correction
- Range
- -4 to +4
- Black
- Designed For
- Panasonic Lumix DMC-LX7 , Panasonic Lumix G DMC-GX1, DMC-GX1K, DMC-GX1WX, DMC-GX1X, DMC-GX1XV
