Take this pocket-sized camera on your next trip. Its powerful 30x zoom lens and 4K Video/Photo recording capability let you save your travel memories in exactly the form you want.
Big zoom, powerful features, little camera
With an indispensable 30x optical zoom, 4K Video and 4K Photo technology all in a pocket sized camera. This camera gives you every detail from far away landscapes and allowing you to capture spur of the moment shots in vivid clarity. Capture all of your unmissable moments on your adventure. -
Powerful engine for low light conditions
Take stunning photos in dimly lit environments with an 18.1-megapixel High Sensitivity MOS Sensor and Venus Engine (the same quality engine that you find in a LUMIX high-end system camera). Capture and edit more details shooting in RAW format allowing you to retain the original color and light information with minimal processing. -
Get closer to the moment
The 24 mm LEICA DC VARIO-ELMAR lens has a 30x optical zoom brings you an intimate view of that unmissable moment during your adventure. -
Capture unmissable moments with 4K Photo
4K Photo allows you to capture that unmissable moment in 30fps and select your best photo after shooting. -
4K Video, life in vivid detail
Record your adventure in up to 4x the quality of Full HD; giving you more excitement, detail and vivid unmissable memories. -
Light composition
Light Composition function synthesizes the images by choosing and saving a brighter pixel. This makes it possible to produce more luxurious, dramatic image of situations such as fireworks or night scenery in camera with ease. -
4K live cropping
4K Live Cropping enables unique video expressions that were previously difficult to record. Only the recording frame moves while the camera maintains a fixed position. This allows stable panning, and lets you zoom in on a subject that is not in the image's center position. -
Shoot now, focus later
Decide what you want in focus, after you've taken the photo. The Post Focus function gives you the power to do just that. Simply capture the scene, review the image and touch the part of the photo you'd like to be pin sharp. A simple feature that will help you capture that stunning shot. -
High speed auto-focusing with DFD technology
Panasonic's Depth From Defocus (DFD) Auto Focus (AF) technology instantly calculates the distance between the items inside the frame and drives the focus of the lens in one fast, continuous movement. This system results in faster AF speeds up to 0.1 seconds and a burst shooting speed with AFC of 5 fps. It also increases the stability of continuous focusing when shooting video. -
Focusing in low light conditions - Star Light AF
Low Light Auto Focus makes it possible to set focus on the subject more precisely in such as moonlight even without AF assist lamp. Furthermore, the LUMIX TZ80 integrates the Starlight AF to let you shoot a star in the night sky with auto focus by accurate calculation of the contrast value in a smaller AF zone.
- Panasonic Lumix DMC-TZ80 - digital camera - Leica
- Product Type
- Digital camera - 4K - compact
- Lens Included
- Leica
- Memory Card Slot
- SD card
- Wireless Interface
- Wi-Fi
- Sensor Resolution
- 18.1 Megapixel
- Max Video Resolution
- 3840 x 2160
- Lens System
- Zoom lens - 30x zoom - 4.3 - 129 mm - f/3.3-6.4 DC Vario-Elmar
- Focus Adjustment
- Automatic
- Min Focus Distance
- 50 cm
- Image Stabiliser
- Optical (HYBRID O.I.S. +)
- Camera Flash
- Built-in flash
- Viewfinder
- Built-in - 0.2" - colour - electronic
- Display
- LCD display - 3"
- Supported Battery
- 1 x Li-ion rechargeable battery - 1025 mAh (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Silver
- 11.2 cm x 3.8 cm x 6.4 cm
- 240 g
- Product Type
- Lens Included
- Leica
- Enclosure Colour
- Silver
- Sensor Resolution
- 18.1 Megapixel
- Optical Sensor Type
- CCD
- Total Pixels
- 18,900,000 pixels
- Effective Sensor Resolution
- 18,100,000 pixels
- Optical Sensor Size
- 1/2.3"
- Frame Rate (Max Resolution)
- 25 fps
- ISO (Max)
- 6400
- Optical Zoom
- 30x
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Print Standard
- DPOF support, Exif Print support, PictBridge support
- Auto Focus
- TTL contrast detection
- Auto Focus Points (Zones) Qty
- 49
- Face Detection
- Face Detection AF/AE
- Digital Video Format
- AVCHD, H.264
- Image Recording Format
- JPEG, RAW, RAW + JPEG
- 3840 x 2160
- Interface
- Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n
- Computer Connectivity
- Mac, Windows
- Connectivity Features
- Remote control via mobile devices, remote live view
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO 6400, ISO 3200, ISO auto
- Exposure Metering
- Multi-segment, centre-weighted, spot
- Exposure Modes
- Programme, automatic, manual, aperture-priority, shutter-priority
- Shooting Programs
- Blue Sky, splashing water, night landscape, sports mode, sunset, backlight portrait, night snapshot, baby, soft skin, portrait soft, handheld night shot, monochrome, backlit softness, relaxing tone, romantic sunset glow, clear nightscape, cool night sky, warm glowing nightscape, glittering illuminations, soft image of a flower, appetising food, cute dessert, freeze animal motion, vivid
- Special Effects
- Vivid, natural, monochrome, landscape, portrait, Standard
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Incandescent, cloudy, Flash, daylight, halogen, shade
- Max Shutter Speed
- 1/2000 sec
- Min Shutter Speed
- 60 sec
- Exposure Compensation
- ±5 EV range, in 1/3 EV steps
Lens System
- Leica zoom lens - 30x zoom - 4.3 - 129 mm - f/3.3-6.4 DC Vario-Elmar
- Focal Length Equivalent to 35mm Camera
- 24 - 720mm
- Focus Adjustment
- Automatic
- 50 cm
- Macro Focus Range
- 3cm
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 9 groups / 12 elements
- Built-in lens shield, aspherical lens
Camera Flash
- Camera Flash
- Built-in flash
- Flash Modes
- Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator
- Effective Flash Range
- 0.6 m - 5.6 m: ISO auto (wide lens) , 2 m - 2.9 m: ISO auto (tele lens)
Additional Features
- Continuous Shooting Speed
- 2 frames per second, 5 frames per second, 10 frames per second
- Additional Features
- Audio recording, built-in speaker, RGB primary colour filter, digital noise reduction, date/time stamp, digital image rotation, camera orientation detection, histogram display, in-camera red-eye removal, resizing an image, built-in help guide, in-camera RAW processing, automatic display brightness adjustment
Viewfinder
- Viewfinder Type
- Built-in - electronic
- Viewfinder Colour Support
- Viewfinder Diagonal Size
- 0.2"
- Viewfinder Resolution
- 1,166,000 pixels
- Optical Viewfinder Magnification
- 0.46x
Display
- 3" LCD display
- Display Format
- 1,400,000 pixels
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Stereo
- Connector Type
- USB 2.0 (mini-USB Type B) , HDMI (19 pin micro HDMI Type D)
- Included Accessories
- Battery charger, hand strap, USB cable
- Battery Type
- Lithium Ion - manufacturer-specific
- Details
- Battery Life Details
- Photo shooting - 320 shots
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Image Storage
- JPEG 4896 x 3672 , JPEG 3456 x 2592 , JPEG 2400 x 1800 , JPEG 4896 x 3264 , JPEG 3456 x 2304 , JPEG 2400 x 1600 , JPEG 4896 x 2752 , JPEG 3840 x 2160 , JPEG 1920 x 1080 , JPEG 3664 x 3664 , JPEG 2592 x 2592 , JPEG 1824 x 1824
- Video Capture
- AVCHD - 3840 x 2160 - 25 fps - 100Mbps , AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 i - 50 fps - 24Mbps , AVCHD - 1920 x 1080 i - 50 fps - 17Mbps , AVCHD - 1920 x 1080 - 25 fps - 20Mbps , AVCHD - 1280 x 720 - 25 fps - 10Mbps , H.264 - 640 x 480 - 25 fps - 4Mbps
- 11.2 cm
- 3.8 cm
- 6.4 cm
- 240 g
