Panasonic CF-52 WUXGA QM57 2/160 15.4 w7
Quicklinx: 73FNWS00 Mfr#: CF-52MLBBUPE
  • Core i5
  • Microsoft Windows 7 Professional / XP Professional downgrade
  • IEEE 802.11n
This powerful desktop alternative gives you the flexibility to work wherever you need to, whether in the office or in the field. The shock-mounted hard drive, full magnesium alloy casing, and spill-resistant keyboard and touchpad defends your data against the bumps of mobility. The 15.4-inch widescreen display is perfect for increased productivity and better group presentations. Work anywhere. Risk nothing.
Panasonic Toughbook 52 - 15.4" - Core i5 540M - vPro - 2 GB RAM - 250 GB HDD
Notebook - rugged
Operating System
Windows 7 Pro / XP Pro downgrade
Platform Technology
Intel vPro Platform
Intel Core i5 540M / 2.53 GHz (3.07 GHz) / 3 MB Cache
2 GB DDR3
Storage
250 GB HDD
Optical Drive
DVD SuperMulti
Display
15.4" 1920 x 1200 / WUXGA
Graphics
Intel HD Graphics
802.11a/b/g/n, Bluetooth 2.1 EDR, Gigabit Ethernet, fax / modem
Up to 4 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip
35.6 cm x 28.7 cm x 5.2 cm
3.4 kg
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Notebook - rugged
Operating System
Processor / Chipset
CPU
Max Turbo Speed
3.07 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Front Side Bus
1066 MHz
Chipset
Mobile Intel QM57 Express
Platform Technology
Intel vPro Platform
RAM
2 GB
Max RAM Supported
8 GB
DDR3 SDRAM
Storage
Main Storage
250 GB HDD
Optical Drive
DVD±RW (±R DL) / DVD-RAM fixed
Display
15.4"
Resolution
1920 x 1200 (WUXGA)
Widescreen
Anti-glare, anti-reflective
Audio & Video
Graphics Processor
Intel HD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Max Allocated RAM Size
1024 MB
Sound
Stereo speakers
High Definition Audio
Input
Keyboard, touchpad
Scrolling, volume control
Communications
Wireless
Wireless Controller
Intel Centrino Advanced-N 6200
Network Interface
Gigabit Ethernet
IEEE 802.1x
Modem
Protocols & Specifications
ITU V.92
Lithium Ion
7800 mAh
Run Time
Up to 4 hours
AC Adapter
Input
Connections & Expansion
Slots
1 x PC Card (1 free) , 1 x ExpressCard/54 (1 free)
VGA , Headphone output , Microphone input , Dock , Serial , 4-pin FireWire , 4 x USB 2.0 , LAN , Modem
Memory Card Reader
Yes (SD Card, SDHC Card)
Software
Software Included
Drivers & Utilities, DMI Viewer, Intel PROSet, Loupe Utility, PC Information Viewer, Hotkey Settings, Battery Recalibration Utility, PC-Diagnostic Utility, Wireless Switch Utility, Toshiba Bluetooth Stack, Adobe Reader, Hard Disk Data Erase Utility, Icon Enlarger, Infineon TPM Professional Package, recovery DVD
Dockable
Security
Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, anti-vibration, spill resistant keyboard
ACPI, AES
3.4 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
