Easily capture distant objects that are too far away to shoot with conventional zoom functions - thanks to 90x Intelligent Zoom. You can also use the 50x Optical Zoom to zoom in on your subject to add more emotion and dynamics to your homemade footage. Fit more people and more of the background into the frame - the 28 mm Wide-Angle function (35 mm camera equivalent) makes it possible. This is especially handy when you want to take a group shot in a small room. It fits objects in even when you shoot from up close, and makes it possible to pick up even small sounds with the camcorder's built-in microphone. This model includes a rotatable sub camera that lets you take shots from two angles at once. For example, you can capture the family and a selfie, or both tele and wide-angle shots. A Backup function records a picture in picture image and a main camera image without a sub window for backup. The sub camera image is recorded into any one of various sub windows, and its display position can be changed by touch operation.
90x intelligent/50x optical zoom
Easily capture distant objects that are too far away to shoot with conventional zoom functions - thanks to 90x Intelligent Zoom. You can also use the 50x Optical Zoom to zoom in on your subject to add more emotion and dynamics to your homemade footage. -
28 mm wide-angle
Fit more people and more of the background into the frame - the 28 mm Wide-Angle function (35 mm camera equivalent) makes it possible. This isespecially handy when you want to take a group shot in a small room. It fits objects in even when you shoot from up close, and makes it possible to pick upeven small sounds with the camcorder's built-in microphone. -
Twin camera function
This model includes a rotatable sub camera that lets you take shots from two angles at once. For example, you can capture the family and a selfie, or both tele and wide-angle shots. A Backup function records a picture in picture image and a main camera image without a sub window for backup. The sub camera image is recorded into any one of various sub windows, and its display position can be changed by touch operation. -
Wireless multi camera
Enjoy a kind of shooting style that lets you add even more emotion to your movies. Using Wi-Fi, you can link to as many as three smartphones and simultaneously record up to two of them as sub-windows. These sub-window images can be interchanged, and their display positions can be switched. This lets you shoot from a variety of angles and viewpoints, to capture a higher level of emotional impact. -
HDR (High Dynamic Range) movie
Enjoy crisper, clearer videos thanks to the HDR Movie function. It combines two images taken with different exposures to suppress blown highlights and blocked shadows. Even in difficult shooting situations, such as backlighting, you can easily capture natural videos with excellent gradation. A dedicated HDR button enables quick mode changes when necessary.
- Panasonic HC-W580 - camcorder - storage: flash card
- Product Type
- Camcorder - 1080p - widescreen
- Media Type
- Flash card
- Memory Card Slot
- SD card
- Wireless Interface
- Wi-Fi
- Sensor Resolution
- 2.51 MP
- Effective Sensor Resolution
- Video: 2.2 MP - Photo: 2.2 MP
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 50x zoom - 2.06 - 103 mm - f/1.8-4.2
- Lens System (2nd)
- Lens 2.48 mm - f/2.8
- Focus Adjustment
- Automatic, manual
- Digital Zoom
- 3000x
- Image Stabiliser
- Optical (5-axis HYBRID O.I.S. + with Active Mode)
- Display
- LCD display - 3"
- Supported Battery
- 1 x Li-ion rechargeable battery - 1940 mAh (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Black
- 6 cm x 12.9 cm x 6.2 cm
- 264 g
- Product Type
- Camcorder - 1080p
- Enclosure Colour
- Black
- Camcorder Type
- Consumer
- Camcorder Sensor Resolution
- 2.51 MP
- Sensor Qty
- 1 MOS
- Effective Video Resolution
- 2.2 MP
- Effective Photo Resolution
- 2.2 MP
- Camcorder Interpolated Photo Resolution
- 10.0 MP
- Widescreen Video Capture
- Camcorder Media Type
- Flash card
- Optical Sensor Type
- BSI MOS
- Optical Sensor Size
- 1/5.8"
- Frame Rate (Max Resolution)
- 50 fps
- Optical Zoom
- 50x
- Digital Zoom
- 3000x
- Video Recording Modes
- HA, HG, HE, PH
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Surround Sound
- Dolby Digital AC-3 (2 channel) recording
- Print Standard
- Exif Print support
- Auto Focus
- TTL contrast detection
- Digital Video Format
- AVCHD, H.264, iFrame
- Image Recording Format
- JPEG
- 1920 x 1080
- Interface
- Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n
- Connectivity Features
- Remote control via mobile devices, remote live view, Wireless Twin Camera
Exposure & White Balance
- Min Illumination
- 1 lux
- Exposure Modes
- Programme, automatic
- Special Effects
- Miniature, 8mm Movie, Silent Movie
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Cloudy, sunlight, indoor
- Max Shutter Speed
- 1/2000 sec
- Min Shutter Speed
- 1/2 sec
Lens System
- Focal Length Equivalent to 35mm Camera
- 28 - 1740mm
- Focus Adjustment
- Automatic, manual
- Zoom Adjustment
- Motorised drive
- Built-in lens shield
Lens System (2nd)
- 30.6mm
- Rotating (270°)
Additional Features
- Low Lux / Night Mode
- Additional Features
- Picture-in-picture capability, built-in speaker, takes photos while film recording, USB charging, Live Broadcasting, Intelligent Auto Plus (iA+), Dual Stream Encoding, Time-Lapse recording, Level Shot Function, Creative Control, Twin Camera function, Baby Monitor mode, home security video camera mode
Display
- 3" LCD display
- Display Format
- 460,800 pixels
- Display Form Factor
- Rotating
- Touch Screen
Microphone
- Microphone Operation Mode
- Stereo
- Microphone Features
- Zoom
- Connector Type
- HDMI output (19 pin mini HDMI Type C) , USB 2.0 , Composite video/audio output
Software
- Software
- Drivers & Utilities, Panasonic HD Writer LE 3.0
- Included Accessories
- AC power adaptor, USB cable, HDMI cable
- Battery Type
- Lithium Ion - manufacturer-specific
- Details
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Image Storage
- JPEG 4224 x 2376 , JPEG 1920 x 1080 , JPEG 3408 x 2272 , JPEG 1728 x 1152 , JPEG 3136 x 2352 , JPEG 640 x 480
- Video Capture
- AVCHD - 1920 x 1080 p - 50 fps - 28Mbps , AVCHD - 1920 x 1080 i - 50 fps - 24Mbps , AVCHD - 1920 x 1080 i - 50 fps - 17Mbps , AVCHD - 1920 x 1080 i - 50 fps - 13Mbps , AVCHD - 1920 x 1080 i - 50 fps - 5Mbps , iFrame - 960 x 540 p - 25 fps - 28Mbps , H.264 - 1280 x 720 p - 25 fps - 9Mbps , H.264 - 1920 x 1080 p - 50 fps - 28Mbps
- 6 cm
- 12.9 cm
- 6.2 cm
- 264 g
