Panasonic's PT-DZ6700E 1-chip DLP projectors now offer even brighter and more vivid images with full high definition resolution. The RGB booster combines high brightness and superb color reproduction, a host of technologies work together to enhance image quality. The dual-lamp system and auto cleaning filter extend operating stability and contribute to reliability.expansion to increase system integration flexibility.
RGB booster significantly improves color reproduction
The RGB Booster achieves high image quality with levels of color reproduction and brightness that make each color stand out. It combines Panasonic's proprietary vivid color control technology with a newly engineered lamp modulation drive system for a 1-chip DLP projector that produces bright and vivid colors. -
Multiple terminals with HD-SDI compatibility
The PT-DZ6700E has an array of terminals - two RGB inputs including a 5-BNC connector, a serial in/out terminal, one S-video input, two remote in terminals, one remote out terminal, one DVI-D, and control capability - to support a broad range of projection needs. -
High brightness 6,000 lm with AC Lamp
The 300-watt AC lamps are used in the PT-DZ6700E. The high-efficiency light convergence technology and independently developed color wheel work together to achieve the high brightness of 6,000 lm. Clear, crisp images are reproduced even in bright rooms. -
3D color management system
To increase visual impact, projector images are often viewed from a comparatively close position relative to the screen size. The characteristics of the human eye, however, tend to cause changes in colors when images are viewed close-up on a large screen. Changes in color saturation, hue, and brightness differ from color to color, and conventional projectors were not able to make the appropriate corrections. 3D color management makes these corrections to produce accurate colors that are very close to the original images even when viewed on a large screen. -
System Daylight View 2 for enhanced color perception
Image details are less clear when a projector is used in a room with the lights on. This problem becomes more significant when images require increasing levels of detail expression. Panasonic's System Daylight View 2 optimizes image quality to improve color perception of the projected image in bright rooms. Gamma curves and sharpness, in addition to conventional color correction are adjusted to bring a sense of sharpness to the entire screen and reproduce stunning images with life-like depth. This results in highly comfortable viewing even in bright lighting, and allows viewers to concentrate more easily on the images. -
Detail clarity processor brings depth and clarity to details
This advanced image-processing circuit analyzes the video signal frequency range for each scene by extracting data on the distribution of high, mid, and low-frequency components, and brings out fine details accordingly. The resulting images have a more natural, three-dimensional appearance with crisp, clear detail. -
Dual-lamp system prevents image interruptions
The dual-lamp system increases brightness and eliminates the need to interrupt a presentation if a lamp should burn out. The Lamp Relay mode also operates the lamps alternately to enable 24/7 projector operation. -
Liquid cooling system attains a high level of reliability
Panasonic's original liquid cooling system directly cools the DLP chip, which extends PT-DZ6700E performance and attains a high level of reliability. It also enables operation in temperatures up to 45°C/113°F for use in a wider variety of environments, and maintains a more stable performance even in harsh conditions while keeping the operating sound down. -
Auto cleaning filter reduces maintenance hassles
Panasonic's proprietary Auto Cleaning Filter (ACF) automatically exposes a clean filter surface when it senses that the filter is clogged. The ACF also brushes away dust that adheres to the filter, which helps prevent clogging that can impair operation or cause malfunction. This helps maintain the highly efficient electrostatic filter, the Micro Cut Filter's superior dust-collecting performance. As a result, the filter does not need to be replaced for over 10,000 hours, greatly reducing the hassle of maintenance. -
Side-by-side function
The PT-DZ6700E can simultaneously display images from two sources onto a single screen. For example, you can display a PC image on the left and a video image on the right. Taking advantage of the wide-screen projection, this function gives you a host of new application possibilities to explore.
- Panasonic PT-DZ6700E - DLP projector - standard lens
- DLP projector - 1080p
- Networking
- Ethernet, Fast Ethernet
- Brightness
- 6000 lumens
- Contrast Ratio
- 2000:1
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Lens
- Standard lens
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- 2 x UHM 300 Watt
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Digital Video Standard
- Digital Visual Interface (DVI)
- Video Modes
- 480p, 480i, 1035i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
- Power
- AC 230V (50/60 Hz)
- 800 Watt
- 49.8 cm x 44 cm x 17.5 cm
- 16 kg
- Networking
- Ethernet
- Data Link Protocol
Projector
- Brightness
- 6000 lumens
- Contrast Ratio
- 2000:1
- Image Size
- 127 cm - 1520 cm
- Throw Ratio
- 1.8 - 2.4:1
- Uniformity
- 90 %
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Video Bandwidth
- 162 MHz
- Display Format
- 2,304,000 pixels (1920 x 1080)
- Max Sync Rate (V x H)
- 85 Hz x 91 kHz
- Bulb type
- 2 x UHM 300 Watt
- Liquid Cooling System, Clarity Processor, Noise Reduction, Auto Cleaning Filter, Side-by-Side, Daylight View 2 Technology, 3:2 pull down compensation, PJlink, 3D Color Management
Lens
- Standard lens
- Focus Type
- Powered
- Lens Aperture
- F/1.7-2.0
- Zoom Type
- Powered
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
- Lens Shift Type
- Powered
- Vertical Lens Shift
- 50%
- Horizontal Lens Shift
- 10% / 10%
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, composite video, S-Video, DVI
- Video Modes
Input Device
- External
- 1 x DVI-D input - 24+1 pin digital DVI , 1 x component video / RGB input - BNC x 5 , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - BNC , 1 x S-video input - 4 PIN DIN , 1 x serial RS-232C input - 9 pin D-Sub (DB-9) , 1 x remote control input - mini-phone 3.5 mm , 1 x remote control output - mini-phone 3.5 mm , 1 x remote control input - 9 pin D-Sub (DB-9) , 1 x network - RJ-45
- Included Accessories
- Wireless remote control
- Voltage Required
- 800 Watt
- Power Consumption Operational (Standby)
- 9 Watt
- 49.8 cm
- 44 cm
- 17.5 cm
- 16 kg
- 0 °C
- 45 °C
- 20 - 80%
