The PT-VZ570 offers a blend of high image quality, low Total Cost of Ownership, flexible installation and collaborative functionality.The projector offers a maintenance-free operational life of 7,000 hours when set to eco mode, significantly reducing the Total Cost of Ownership for businesses and educational institutions. The PT-VZ570 allows both portable and ceiling-mounting, while Vertical Lens Shift and Screen Adjustment functionality means easy adjustment of images projected onto flat or curved surfaces, as well as angled projection.
- Panasonic PT-VX600AJ - 3LCD projector - zoom lens
- 3LCD projector
- Built-in Devices
- Speaker
- Brightness
- 5500 lumens
- Contrast Ratio
- 5000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Lens
- Zoom lens
- Lens Shift Direction
- Vertical
- Bulb type
- 270 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Video Modes
- 480p, 480i, 525i, 525p, 625p, 625i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p, 750/50p, 750/60p, 1125/60i, 1125/60p, 1125/50i, 1125/24p, 1125/25p, 1125/30p, 1125/50p, 1080/24sF, 1125/24sF
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 362 Watt
- 38.9 cm x 33.2 cm x 12.5 cm
- 4.8 kg
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Brightness
- 5500 lumens
- Contrast Ratio
- 5000:1
- Image Size
- 76 cm - 762 cm
- Throw Ratio
- 1.2 - 1.9:1
- Uniformity
- 85 %
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Video Bandwidth
- 162 MHz
- Display Format
- 786,432 pixels (1,024 x 768) x 3
- Max Sync Rate (V x H)
- 100 Hz x 91 kHz
- Bulb type
- 270 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction, lens shift dial (vertical)
- 3LCD Technology, PJlink, Dynamic Mode, Eco Mode
Lens
- Zoom lens
- Focus Type
- Manual
- Lens Aperture
- F/1.6-1.9
- Zoom Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -35 / +35
- Horizontal Keystone Correction
- -35 / +35
- Vertical
- Vertical Lens Shift
- 40%
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- HDMI, component video, composite video, RGB
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel - 4 cm
- 2 x HDMI input - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in / microphone input - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C input - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management)
- Included Accessories
- 2 x AAA batteries, wireless remote control
- Security Features
- Security Slot Type
- Kensington security slot
- Power Source
- AC
- Voltage Required
- 362 Watt
- Power Consumption Stand by
- 8 Watt
- Software Included
- Logo Transfer Software, Multi Projector Monitoring & Control Software
- 38.9 cm
- 33.2 cm
- 12.5 cm
- 4.8 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
- Sound Emission
- 37 dB
- Sound Emission (Economic Mode)
- 29 dB
