Panasonic 43in LED Large Format Display 1920 x 1080 Black 350 cd/m2
Quicklinx: C425WS00 Mfr#: TH-43LFE8E
  • 1080p
This slim design allows effective space utilization in stores, showrooms and conference rooms. It is also not oppressive when mounted on a wall. The bezel is about the same width all around the perimeter. This slim bezel design helps viewers concentrate on the screen image. The LFE8 series features a USB media player. Signage operation is possible by simply inputting the desired content via USB, eliminating the need for a set-top box. Both videos and still images can be displayed, so a wide variety of original signage content can be used.
  • Installs in just about any space
  • The slim bezel enhances viewing and replacement
  • Simple signage operation with no set-top box
  • Choose the installation to match your application
    The LFE8 series is often used vertically for menu boards and town guide displays, and can be mounted in landscape, portrait, or multi-screen configuration. This provides information that is easy to see even in relatively high places inside the store, and increases mounting possibilities.
  • Built-in speakers are convenient for videoconferences
    The LFE8 series features built-in speakers. This eliminates the need for external speakers when displaying content with a sound track or when holding videoconferences. There is also no need to consider the space for the speakers when setting up the display.
  • Increased signal support for a wide variety of content
    The number of signals supported by the LFE8 series has been increased. This lets you display the content of various formats. It also saves labor, not only for signage use, but also for reproducing materials in meeting rooms by eliminating the need to convert materials in advance.
  • Bezel adjustment
    When this mode is turned off, a full-screen image of the display panel, including edges (the entire width of the frame), is displayed. This is especially suitable for displaying text information, since no words are hidden by the frame. The image areas that are hidden by borders can be adjusted in both vertical and horizontal directions.
  • Power on screen delay
    For video walls and other multi-unit applications, this function automatically shifts the power-on time slightly for each display unit in the system, so there's less load on the power supply.
  • Input search
    When there is no signal, the specified input signal is automatically switched.
  • Screen saver
    The screen saver reduces the possibility of afterimages or image retention that can occur when displaying still images with constant, unchanging brightness for long periods of time. The auto power off setting can also be set to automatically turn the power off when the screen saver operation ends.
Panasonic TH-43LFE8E LFE8 - 43" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
43"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
575/50i, 575/50p, 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i, 1080/24sF
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
VA
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Input lock, button lock, remote control user level
Speaker System
2 speakers
USB
Remote control, 2 AAA batteries, clamper
Voltage
AC 230V (50/60 Hz)
135 Watt
Power Consumption (On mode)
95 W
Power Consumption Stand by
0.5 Watt
96.9 cm x 6.1 cm x 56 cm
8.7 kg
135 Watt
95 W
Diagonal Class
43"
Commercial Use
Series
LFE8
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, 1:1 Pixel Mode
Timer Functions
Power on delay
Design
Slim Bezel Design
Dimensions
Without stand
96.9 cm
6.1 cm
56 cm
8.7 kg
Enclosure Colour
Display
LCD Display Technology
VA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Direct-lit LED
Image Contrast Ratio
3000:1
Brightness
350 cd/m²
Widescreen Modes
Zoom
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
6.5 ms
Backlight Life
50,000 hour(s)
Commercial Features
Input Search Function
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM, NTSC4.43, PAL-M, PAL-N, PAL60
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 852 x 480, 1152 x 870, 640 x 400, 1920 x 1080, 1066 x 600, 1400 x 1050
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Driver Details
Main channel speaker: 2 x full-range driver - 1.18 x 3.15"
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Supported Consumer Electronics Control (CEC)
PJ Link
Connector Type
2 x HDMI , DVI-D input , Audio line-in , Audio line-out , VGA input , LAN , Serial , USB , Remote control input , Remote control output , Composite video input
Power cable - 1.8 m
IEC 60950-1, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, IEC 62087 Edition 2, IEC 61000-3-3:2013, EN 55024:2010, EN 55022:2010 Class A
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.5 Watt
Power Consumption Sleep
0.3 Watt
Width (Shipping)
107 cm
Depth (Shipping)
15.9 cm
Height (Shipping)
69.6 cm
Weight (Shipping)
14 kg
20 - 80% (non-condensing)
