Panasonic 2600 Lumens XGA LCD Meeting Room Projector 2.99kg
Quicklinx: 8JM8WS00 Mfr#: PT-LX26EA
Marketing description is not available.
Panasonic PT-LX26EA - 3LCD projector - portable
3LCD projector
Brightness
2600 lumens
Contrast Ratio
500:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
UHM 230 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
297 Watt
34.9 cm x 24.7 cm x 10.5 cm
2.9 kg
3LCD projector
Projector
Brightness
2600 lumens
Contrast Ratio
500:1
Image Size
76 cm - 762 cm
Uniformity
85 %
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Video Bandwidth
140 MHz
Display Format
2,359,296 pixels (1024 x 768) x 3
Max Sync Rate (V x H)
100 Hz x 100 kHz
Bulb type
UHM 230 Watt
Bulb life cycle
OSD Languages
Danish, Hungarian, Czech, Thai, Vietnamese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Romanian, Japanese, Korean, Kazakh
Closed Caption, 3LCD Technology, Auto Vertical Keystone, Direct Power Off
Lens
Focus Type
Manual
Lens Aperture
F/2.1-2.25
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video
Video Modes
Speakers
Speakers
1 x mixed channel
Input Device
External
1 x component video / RGB / S-video - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x serial RS-232 - 9 pin D-Sub (DB-9)
Wireless remote control
1 x VGA cable
297 Watt
Software Included
Logo Transfer Software
34.9 cm
24.7 cm
10.5 cm
2.9 kg
5 °C
35 °C
20 - 80% (non-condensing)
Sound Emission
34.1 dB
29 dB
