- Panasonic PT-LX26EA - 3LCD projector - portable
- 3LCD projector
- Brightness
- 2600 lumens
- Contrast Ratio
- 500:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- UHM 230 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Video Modes
- 480p, 720p, 1080i, 480i, 576i, 576p
- Power
- AC 120/230 V (50/60 Hz)
- 297 Watt
- 34.9 cm x 24.7 cm x 10.5 cm
- 2.9 kg
- 3LCD projector
Projector
- Brightness
- 2600 lumens
- Contrast Ratio
- 500:1
- Image Size
- 76 cm - 762 cm
- Uniformity
- 85 %
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Video Bandwidth
- 140 MHz
- Display Format
- 2,359,296 pixels (1024 x 768) x 3
- Max Sync Rate (V x H)
- 100 Hz x 100 kHz
- Bulb type
- UHM 230 Watt
- Bulb life cycle
- OSD Languages
- Danish, Hungarian, Czech, Thai, Vietnamese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Romanian, Japanese, Korean, Kazakh
- Closed Caption, 3LCD Technology, Auto Vertical Keystone, Direct Power Off
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.1-2.25
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, composite video
- Video Modes
Speakers
- Speakers
- 1 x mixed channel
Input Device
- External
- 1 x component video / RGB / S-video - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x serial RS-232 - 9 pin D-Sub (DB-9)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Voltage Required
- 297 Watt
- Software Included
- Logo Transfer Software
- 34.9 cm
- 24.7 cm
- 10.5 cm
- 2.9 kg
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
- Sound Emission
- 34.1 dB
- Sound Emission (Economic Mode)
- 29 dB
