The Platinum True Wireless EarPods are the perfect earbuds for any occasion with 5.0 Bluetooth with 16 hours battery life (4hrs EarPods and 12hrs from the case).
These EarPods have 4 built in mics for Active Noise Cancellation (ANC) as well as clearer phone calls with Environmental Noise Cancellation (ENC) so you can go from the gym to the office effortlessly. The Platinum EarPods are designed to have a secure and comfortable in ear fit that can be adjusted with the different earbud options. With touch functionality these can be worn for hours on end.
These EarPods are also great for the planet, being 100% carbon neutral, 200% plastic regenerative and 100% recycled FSC certified packaging you can listen knowing they are also repairing the planet.
Exceptional audio clarity
Experience audio clarity with the Platinum's Environmental Noise Cancellation (ENC) technology, ensuring your calls and music are heard in clear stereo sound without the interference of background noise. -
Wireless freedom
Embrace wireless connectivity with Bluetooth technology, allowing you to move freely without the constraints of cables, perfect for the dynamic listener on-the-go. -
All-day comfort
Designed with built-in microphones and active noise-canceling, the Platinum headphones offer both immersive sound and the comfort needed for extended listening sessions, making them an ideal choice for portable electronics. -
Long-lasting battery life
With a rechargeable battery, these headphones are built to last and keep you connected to your music and calls, ensuring you stay powered throughout the day without the need for constant recharging.
 - Our Pure Planet Platinum - true wireless earphones with mic
- Product Type
 - True wireless earphones - Bluetooth
- Recommended Use
 - Portable electronics
- Headphones Form Factor
 - In-ear
- Wireless Technology
 - Bluetooth
- Bluetooth Version
 - Bluetooth 5.0
- Sound Output Mode
 - Stereo
- Audio Specifications
 - Frequency Response 20 - 20000 Hz - Sensitivity 105 dB +/- 3dB
- Impedance
 - 16 Ohm
- Active Noise Canceling
- Microphone Noise Cancelling
- Microphones Included
 - 4
 - 2-year warranty
- Product Type
 - True wireless earphones - Bluetooth - wireless
- Dimensions & Weight Details
 - Charging case: 26.5 g
 - 4.5 g
- Recommended Use
 - Touch control
Audio Output
 - In-ear
- Connectivity Technology
 - Wireless
 - Bluetooth
- Bluetooth Version
 - Bluetooth 5.0
- Bluetooth Profiles
 - Headset Profile (HSP), Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
 - Stereo
- Active Noise Cancelling Technology
 - Adaptive Noise Cancellation
 - 20 - 20000 Hz
- Sensitivity
 - 105 dB +/- 3dB
- Impedance
 - 16 Ohm
- Diaphragm
 - 9.3 mm
 - Ambient Aware
Microphone
- Form Factor
 - Built-in
 - 4
- Noise Cancelling
- Noise Cancelling Technology
 - Environmental Noise Cancellation (ENC)
- Included Accessories
 - Charging case
 - FSC
- Battery
 - Rechargeable
- Run Time (Up To)
 - 4 hour(s)
- Run Time Details
 - Continuous playback (with included charging case): up to 16 hours
- Recharge Time
 - 2 hours
 - Limited warranty - 2 years
