Our Pure Planet Platinum Bluetooth Speaker
Quicklinx: HRBMWS00 Mfr#: OPP054
Speaker Type: Speaker
Connection: Wireless
Hurry, only 1 left in stock!
£47.49 ex VAT
£56.98 inc VAT
Express delivery Order within the next hour for delivery tomorrow
The Platinum speaker by Our Pure Planet is a testament to sound quality and durability. Designed for portable use, it features an integrated microphone, making it perfect for hands-free calls, alongside a robust 3000 mAh rechargeable battery ensuring your music lasts. With Bluetooth 5.0, it offers versatile wireless connectivity, allowing you to stream your favorite tunes effortlessly. The speaker is not only water-resistant, thanks to its IPX4 rating, but also adheres to FSC standards, highlighting Our Pure Planet's commitment to environmental sustainability. Whether you're at home or on-the-go, the Platinum speaker delivers continuous power of 10 W, providing clear and powerful sound across a frequency response of 100 - 20000 Hz. Its comprehensive controls, including play/pause, volume adjustment, and power on/off, ensure a user-friendly experience. Embrace the blend of performance and portability with the Platinum speaker.
  • Versatile connectivity
    Equipped with Bluetooth 5.0, the Platinum speaker from Our Pure Planet offers seamless wireless connectivity, allowing you to enjoy your favorite music without the hassle of wires. Its compatibility with a wide range of Bluetooth profiles, including A2DP, AVRCP, and HFP, ensures a versatile and comprehensive audio experience.
  • Durable design
    Designed with portability in mind, this speaker doesn't just bring your music wherever you go; it's also built to last. With an IPX4 water-resistant rating and compliance with FSC standards, the Platinum speaker is ready for any adventure, ensuring your music plays on, no matter the weather.
  • Long-lasting battery life
    The Platinum speaker is powered by a 3000 mAh rechargeable battery, offering extended playback time so you can enjoy your music for longer periods. USB charging options add convenience, making it easy to recharge the speaker wherever you are.
Our Pure Planet Platinum - speaker - for portable use - wireless
Speaker - for portable use
Protection
Water-resistant
Speaker Type
Active
Continuous Power
10 Watt
Frequency Response
100 - 20000 Hz
Amplifier
Integrated
Bluetooth
Speaker Details
Speaker - 10 Watt - 100 - 20000 Hz - active
Power Options
USB charging
Speaker battery rechargeable
18.5 cm x 7.5 cm x 7.5 cm
500 g
Hands-Free Function
Microphone
Protection
Water-resistant
Speaker System
Speaker Type
Active
Continuous Power
10 Watt
Frequency Response
100 - 20000 Hz
Amplifier
Integrated
Bluetooth 5.0
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Hands-Free Profile (HFP), Human Interface Device Profile (HID), Audio/Video Control Transport Protocol (AVCTP), Audio/Video Distribution Transport Protocol (AVDTP), Serial Port Profile (SPP)
Controls
Power on/off, volume, play/pause, play mode, call answer/end
Speaker System Details
Speaker Details
Speaker - 10 Watt - 100 - 20000 Hz CFR - active
Driver Details
Speaker: full-range driver
Micro-USB charging cable
IPX4, FSC
Power Source
Options
USB charging
Rechargeable
Capacity (Ah)
3000 mAh
Run Time (Up To)
10 hour(s)
18.5 cm
7.5 cm
7.5 cm
500 g
Brand: Our Pure Planet
